Posted November 25, 200717 yr comment_229666 I noticed today that there is a "growl" or low "grrrrrrrr" not a "whine" coming from the rearend of the car ONLY when I'm coasting....You give it any gas at all and the noise stops, but then as soon as you come off the gas and coast there's that noise again. What in the world could this be??? What should I look for and would you drive the car anymore...... Thanks guys.... Link to comment https://www.classiczcars.com/forums/topic/26338-new-noise-todayshould-i-stop-driving/ Share on other sites More sharing options...
November 25, 200717 yr comment_229693 Check the rear end oil? Link to comment https://www.classiczcars.com/forums/topic/26338-new-noise-todayshould-i-stop-driving/#findComment-229693 Share on other sites More sharing options...
November 25, 200717 yr comment_229707 are you sure its from the rear end? it sounds like you need a new release bearing. Link to comment https://www.classiczcars.com/forums/topic/26338-new-noise-todayshould-i-stop-driving/#findComment-229707 Share on other sites More sharing options...
November 25, 200717 yr comment_229708 Short of pulling the rear.drop the oil and fill it with 140 weight gear lube.Never telling what the PO put in there. Link to comment https://www.classiczcars.com/forums/topic/26338-new-noise-todayshould-i-stop-driving/#findComment-229708 Share on other sites More sharing options...
