Email logins are now active ×
why no pressure?
joerocket
ive pulled the fuel tank and flushed it out. ive blown through all the fuel lines. ive also pulled the pump which runs just fine. but when i put it back together i pulled the oil pressure sensor to bring the fuel pump on and seperated the fuel line below the filter and i am getting nothing. ive heard it can be difficult to prime the pump but i have at least 7 to 10 gallons of gas. what gives?
"ive pulled the fuel tank and flushed it out"
Ok, how long has the car sat and how old was the fuel you took out? The bosch L Jetronic uses a Roller vane pump. The roller cell is driven by an electric motor at over 3,500 RPM. This pump is capable of pressure in excess of 100 PSI which is far higher than any engine or F.I. system require. This is why this type of pump is located very close to or even inside the fuel tank because it does such an excellent job at pushing the fuel. My guess is A) it's just tired out internally or B) is junked up from the old rusty fuel, or C) both. I don't know how far you have gone looking at the fuel pump, but Just a thought.
Normally a bad pump will bypass a driveability problem and will just simply stop operating so typical? no, but it has and can happen and considering your Z sat for months without a gas gap and had some nasty crap ran through it, we are not talking about normal wear and tear here so I wouldn't rule out the possibility.
  • Who's Online   2 Members, 0 Anonymous, 658 Guests (See full list)
