Posted August 14, 200222 yr comment_12874 I have a 71 240z.I put a 81 280zx 5 speed trans in it to find out that the middle console is in the way of 1st 3rd and 5th geers.my question is should I cut the console which I would hate to do or is their another console that I could buy that would fitif any one has had this problem I would like to here from youthanxzeke Link to comment https://www.classiczcars.com/forums/topic/2637-cut-middle-console-to-fit-5speed-shifter/ Share on other sites More sharing options...
August 14, 200222 yr comment_12899 I've believe a shifter from a 280Z will fit without cutting. I've got a 5-speed from a ZX and I believe the shifter is from a 280Z - there are no cuts and it fits and shifts through the gears without hitting. Link to comment https://www.classiczcars.com/forums/topic/2637-cut-middle-console-to-fit-5speed-shifter/#findComment-12899 Share on other sites More sharing options...
August 29, 200222 yr comment_14337 The problem may be that you have an early 1971 240Z (made before January 1971) with the f4w71A 4 speed transmission and you now put a newer B-series transmission into it. Nissan started using B-series transmissions in late 1971 and newer 240Zs and then replaced them with B-series 5 speeds in the 280Z.Try to find a 1972-73 240Z console (including the choke cable assembly) and swap it in place of the 1971's. Link to comment https://www.classiczcars.com/forums/topic/2637-cut-middle-console-to-fit-5speed-shifter/#findComment-14337 Share on other sites More sharing options...
September 1, 200222 yr comment_14534 The transmission should bolt up fine, then swap a shifter handle from a '78 280Z that was a 5-speed and you should be fine. Link to comment https://www.classiczcars.com/forums/topic/2637-cut-middle-console-to-fit-5speed-shifter/#findComment-14534 Share on other sites More sharing options...
