Posted November 27, 200717 yr comment_229968 the book shows the fuel lines going into the tank side by side. but my 2/78 280z has them stacked. which one was the feed and which is the return? Link to comment https://www.classiczcars.com/forums/topic/26370-fuel-tank-hook-up-lines/ Share on other sites More sharing options...
November 27, 200717 yr comment_229980 Top is feed, bottom is return. Link to comment https://www.classiczcars.com/forums/topic/26370-fuel-tank-hook-up-lines/#findComment-229980 Share on other sites More sharing options...
November 27, 200717 yr Author comment_229981 when both are disconnected the return leaks fuel and the feed does not. is that right? i can suck it out but it doesnt leak on its own. Link to comment https://www.classiczcars.com/forums/topic/26370-fuel-tank-hook-up-lines/#findComment-229981 Share on other sites More sharing options...
November 27, 200717 yr comment_229985 I've never tried that but I know that the upper hose is the one that connects to the fuel pump inlet and the lower one ultimately connects to the pressure regulator after passing through the lines that lead it there. Link to comment https://www.classiczcars.com/forums/topic/26370-fuel-tank-hook-up-lines/#findComment-229985 Share on other sites More sharing options...
