Staggered wheels on a 73
Topher
Couldn't find much searching.
Found an incredible set of wheels at a good price.
Fronts are 16x7 +13, rears are 16x8 +14
Any concern with the offset or width?
I will likely run a 225/50 tire, I am not too nervous about rolling my fenders.
Currently, I am on Eibach springs and Tokico struts (with plenty of room).
You can view pictures here: http://www.classiczcars.com/forums/showthread.php?p=237803#post237803
I forsee myself moving to AZC coilovers in the next year or so.
Anything here scare you? Should any of it scare me? :)
Heres a quote i found on "the other site"
"1972 240z, Sportmax 16x8 0 offset wheels, 225/50-16 tires. Car lowered slightly.
Rear tire sidewalls rub on uneven terrain and during bumpy corners.
Will adjust ride height up and add rear sway bar to stiffen. If that doesn't do it, will move rear springs to front and use stiffer in rear.
UPDATE 051107
Ride height adjusted up .6". New trim height is 26.1" measured from ground to fender lip at wheel centerline. Added Suspension Techniques rear sway bar (nicely engineered btw)
Rear springs are 170 lb/in
Verdict - Still rubs on extreme bumps. Will move rear springs to front and use 200 lb/in in back."
I am not sure, but a +14 offset may be a little to close to rubbing the strut. Hope this helps!
Well around here we call Hybridz.org "the other site". Why, I have no idea.
Here is another quote I found that may be of interest to you....
"So i have a set of rims 15x8 with a 2mm offset or so the sticker on the rim says i still need to measure backspace to be sure .
I just mounted a wide set of tires 295/50/15 11 inch wide tread 12 inch wide sectional 27 tall if i remember . Ive lowered the car 1 1/2 inches over stock only issue is i have 1/8th of a inch between the rubber and the rear spring lower perch . "
Yeah. I remember my dad put a 15x8 wheel with a 295/50 tire on rear of his 280zx, and they fit right in there perfectly. I dont remember the offset though. Just so you know, if you put a 225 tire on a 8 inch wide wheel, the tire will looked slightly stretched...most 225's are meant for min. 6" max. 8" wide wheels.
There is more room between the mounting surface and the strut in the rear than there is on the front wheels.
I did some measuring and estimating on my car several years ago when I was looking at wheel/tire combinations. In my notes I see that I had some estimates of maximum offset that show something like 5 inches of maximum back spacing with the stock struts. That would give your 225's a max offset of about 10mm.
But 215's would very likely work with a 13mm offset. I admit that I was trying to be safe with the 5 inches as well. It might work, but it would be really close.
  • Who's Online   2 Members, 0 Anonymous, 417 Guests (See full list)
