I have heard that earlier 240Zs have two different tach wiring setups, but haven't heard the same said about 1973 models. My fiche shows 24855-N3301 for tachs dated 8/72-7/73 and 24855-N3600 for 8/73-8/74. While the part numbers supercede, I bet it's the same tach since (IIRC) the wiring changes between the two years are not substantial...
Maybe PM one of the 260Z owners?
  • 1 year later...
I would like to know if all tach from 240z to '77 280 has the same wiring? or the same plug and play?
I bought one in ebay today.
This is the tach. let me know if these would work on the 280z.
Definitely a 280z tach by the plug and mounting technique. Which year? I'm leaning toward 77-78 by the font on the face, but some else might chime in. Likely work on any 280z with a matching plug.
The tach connections are the same for all 75-78 280z, +12v (blue), ground (Black) and a trigger (Blue/White, all harness side, not tach wires) from the negative side of the coil (via a 2.2K ohm resistor), so any 280 tach can be made to work if the plugs are not the same.
Jim
Guest
Reply to this topic...
