The State of Things....
WingZr0
WoW that look nice Bro!
Oh yeah, you going with old style rims or New School?
I'm going w/ 15" Panasports. The wheels arrived yesterday!
They are silver, but I'm thinking of painting the spokes a medium gray metallic, but not as dark as Panasport's "gunmetal" color.
  • 5 weeks later...
full house said:
Quote:
Originally Posted by dogma420
$1000 for a clutch? is that what that said? or was that for brakes too?
$ 1000 for a clucth? where did you get that?
Uhh, I read the post....what's your excuse?
Ruby's finally at the shop now ^_^ !
Nakatsu's been extreamly busy working on at first 3, now 5 other
race cars getting them ready for the up coming race season for other
customers.
So today I got her towed into the shop and put down a deposit for a
complete engine rebuild.
Both engine and trans are coming out!
Engine Block is going into a machine shop (for lack of a better term) to get a
complete check over, decked and all the standard things associated with
that kind of work.
Estimated time to get to start work on her is around first part of April with
completion time of around 1 to 2 months depending on how bad the
damage is and upgrades I may add along the way, and of course $ :smoke:.
Things on the work order list so far are
~Piston Rings
~New Piston Heads if need be
~ARP head bolts and connecting rod bolts
~Kameari high capacity oil pump
~New water pump which I may go with the MSA Electric version
~New MSA Aluminum Radiator (Maybe)
~Cap and Rotor (manditory)
~Stock timing chain
~MSA 3-2-1 header with 2 inch down pipe connected to NOS ANSA Twin
Stack with 2 inch inlet diameter
(Cat Converter will be made to swap in and out easily for smog test days)
~New Stock Cam
(depending on if the stock cam that came with the rebuilt
cylinder head is actually good are not. We will likely be taking the new
head apart and rechecking it to make sure it's all up to spec.)
~Oil preasure sender
~Raising rate fuel preasure regulator
~All new matching injectors and connectors
~Check Fuel Pump
~Check AFM and Throttle Body
~Check to see if Gas Tank need to be boiled out
~Replace any sensors that are bad along with Cold Start Valve if need be
~New stock brakes and SS lines and wheel bearings
~New polyurethane suspension bushings most likely
~Check entire suspension componets just to be safe
~Quick steering knuckles
~Painting hood Gloss Black to fix that unsightly 4 inch bondo crack on
the my hood bulge.
What is that hood bulge actually called by the way :cheeky:
and should I paint the hood only or hood, inspection lids and
cowl panel GB for that "Arrow Head" look?
OK, so other than that just your basic engine rebuild.
I know some of the things I listed are standard for a rebuild but
thought I'd list them jus the same.
Everthing will be done to still pass smog ( Thyanx Blake ~_^ ).
Also going to seriously look into that Mega Squirt set for later on after
talking more in depth about it with Nakatsu.
I believe this is the link -> http://www.bgsoflex.com/megasquirt.html
He was actuallly suprised to know they were still around and that I
knew about them.
We were even talking some about the new AEM EMS set up that came
out last year, the one were you have to mail it in to have them (AEM)
program the engine parameters you like so you can tune it later when
you get it back in the mail.
Supposedly it's cheaper than the old system they were using at around $6K.
http://www.aempower.com/
And case your wondering why I'm painting the hood Black is
because I'm not sure if the new Dupont 51013 Sparkling Burgundy Poly will
be too bright for the rest of car untill I can get it complety repainted at
a later date.
Nothing says yuck like a non matching body panel of "same" color LOL
OH yeah, I posted this number for somebody once but the number has changed,
Nakatsu's Garrage / NS Garage
Dean Nakatsu
530-632-2761, shop # 530-674-7223
NSGarage1@yahoo.com
Wheeu, now I need a 2nd job ROFL :rambo:
~Z~
Maybe you should change that to:
Quote:
Spending is fun,
As long as you out run,
The cops! ! !
But seriously, Ruby should run great after all of that.
HAHAAAA HAHAHAHA
ROFL Truer words have never.... ROFLROFLROFLROFL
Yah did warn me she would take my money,
I jus didn't know how much ^_^
~Z~
  • 1 month later...
Rubys engine finally comes out this weekend !
'88 Acura daily driver choosen NOW to fall apart though.
Already in it for $500 dollors minimum in repair bills to fix, CV Axle boot busted and
lost oil, Tail Lights and Dash Lights turn off when Head Lights are
switched on now, and I just bought the thing less a month ago :eek:
Yeah they call it an Acura Legend, but I now call it
The ACURA BUCKET !
piece of junk
~z~ LOL
  • 3 weeks later...
Engines' FINALLY OUT ! ahoy.gif WOO HoooOOO !
The clutch flywheel and such looks good (AATCO did thier job :tapemouth)
and so far we know we need a new engine harness or at least the
needed connectors and the radiator is SHOT.
Other than that the basic routine tear down will commence with more
updates on what a Carburetor gasket on a FI Z will do :surprised.
JE pistons have been added to the list as opposed to the COSWORTHS which
I was gonna get but we all know how expensive those can be, $1,700 for a
set of six!
This months Dsport magizine has a speed shop section on pistons, how
they work and the makers of such high quality parts :) click on sig below
for more :).
Also might get the JE's made as custom specs but more on that later but
advice is also welcomed since I'm blind to that much of it LOL.
Well back to the shop I go, Thyanx for your support so far guys ^_^
Progress is always great!
