Email logins are now active ×
when replacing mass air flow meter,anything need to be reset?
gblaine
that's why i said maybe try unpluging it. that would open the fuel pump circuit, AND the car should run with it unplugged (i've done it before, but it runs like arse)
I've done a lot of research on this over the years. He has a 75 and you have a 78 as do I. The 78 S30 does not have fuel pump contacts in the AFM. It's the only year S30 that doesn't. It's setup like the later 79 and up S130, 810 and Maxima units (Pre ECCS). That's why the FSM cautions against using the 78 and later ECU or AFM in the 77 and earlier 280Zs. Unplugging the AFM on a 78 doesn't 'open the fuel pump circuit'. Compare these two scans. The only reason your car runs like 'arse' when you unplug the AFM is simply because you've unplugged the AFM. It really doesn't accomplish or help diagnose anything.
sorry blake, i'm never good at explaining things.
when i looked at my plug, the plug has 2 contact points that are empty (no wires leading to them) I know that mine doesn't use the switch, but from my understanding, when the car is running, the switch is opened because the flap has moved. by unpluging the afm from the car, that switch would become an open circuit. that's all i was saying. (or, the easy way would just be shove a screwdriver to push the flap and see if it kicks the pump on.)
What switch? There is no 'switch' in a 78 and up AFM as evidenced by the fact that there are no wires on the plug, as you said, that would correspond to the contacts on the earlier cars. Maybe you'll understand it better with these charts. On a 78 the position of the flap in the AFM has no effect on the operation of the fuel pump. That may work on his car but it won't on yours or mine.
  • Who's Online   1 Member, 0 Anonymous, 705 Guests (See full list)
