Posted December 11, 200717 yr comment_231061 Hey guys, My new diamond vinyl just came in from Les today and I was wondering what would be the best way to install it. Aerasol spray adhesive? what brand? Where do I start? Any tips or tricks....etc. Any help would be appreaciated. Here is what it looks like right know...... Thanks, Randy Link to comment https://www.classiczcars.com/forums/topic/26477-new-vinyl-install/ Share on other sites More sharing options...
December 11, 200717 yr comment_231063 Randy,I had spotty performance from spray adhesive when used on vinyl attached directly to metal. For that I used Weldwood contact cement (available at Lowe's et al), applied to both sides and allowed to tack up for at least 30 minutes. Apply to metal carefully, as it's tough to reposition. I did some dry runs over the rear wheel areas to be sure it would work out. I used spray adhesive on the luggage riser vinyl, and will have to go back and reapply with contact cement.I did use spray adhesive (bought from an upholstery shop) when attaching vinyl to the trans tunnel padding. It has adhered quite well so far.Good luck,SteveBTW, what's wrong with your old stuff? Won't clean up well? Shredded? Link to comment https://www.classiczcars.com/forums/topic/26477-new-vinyl-install/#findComment-231063 Share on other sites More sharing options...
December 11, 200717 yr comment_231064 Just did mine, used 3m 77 series spray. Link to comment https://www.classiczcars.com/forums/topic/26477-new-vinyl-install/#findComment-231064 Share on other sites More sharing options...
December 11, 200717 yr comment_231065 I used 3M 77 spray and it is coming loose three months later. I am going back with Weldwood contact cement. Link to comment https://www.classiczcars.com/forums/topic/26477-new-vinyl-install/#findComment-231065 Share on other sites More sharing options...
December 11, 200717 yr Author comment_231132 Thanks guys,My old stuff was very fadded and stained, plus I got the new seat covers and wanted the vinyl to match.Looks like Weldwood is the way to go, I'll post some "after" pictures hopefully soon. Link to comment https://www.classiczcars.com/forums/topic/26477-new-vinyl-install/#findComment-231132 Share on other sites More sharing options...
December 12, 200717 yr comment_231152 Yes, I'll need to reattach my vinyl to the transmission tunnel as well. Passenger side is perfect, but driver's side is loose. Let us know how the Weldwood goes... Link to comment https://www.classiczcars.com/forums/topic/26477-new-vinyl-install/#findComment-231152 Share on other sites More sharing options...
December 16, 200717 yr comment_231537 77 adhesive looses its grip in hot temperatures, i used it to attach vinyl on another car and it started to cause creases where the adhesive let up. weldwood should work though. or maybe 3m 90 Link to comment https://www.classiczcars.com/forums/topic/26477-new-vinyl-install/#findComment-231537 Share on other sites More sharing options...
December 19, 200717 yr comment_231773 At first I was concerned about getting the vinyl on straight using the contact cement but, turned out great. The glue was more forgiving then I expected. The installation looks much better this time. Link to comment https://www.classiczcars.com/forums/topic/26477-new-vinyl-install/#findComment-231773 Share on other sites More sharing options...
December 19, 200717 yr comment_231780 I've been using weldwood for years with no issues-the last four or five I used the gel version, and found it easy to work with-not that the non gell is difficult...Eill Link to comment https://www.classiczcars.com/forums/topic/26477-new-vinyl-install/#findComment-231780 Share on other sites More sharing options...
