Posted December 12, 200717 yr comment_231199 were it the ecu located. Link to comment https://www.classiczcars.com/forums/topic/26493-78-280z-ecu-location/ Share on other sites More sharing options...
December 12, 200717 yr comment_231201 It is on the interior of the car, drivers side, under the dash, to the left of the pedals. Basically the same vertical wall as where the fuse box is, but on the drivers side. Link to comment https://www.classiczcars.com/forums/topic/26493-78-280z-ecu-location/#findComment-231201 Share on other sites More sharing options...
December 12, 200717 yr comment_231202 The ECU is in the passenger compartment, driver side, just in front of the leading edge of the door. However, if you are thinking that it is the cause of your recent issues of car not wanting to run, I would start looking elsewhere first. The ECU in our era of vehicle was really nothing more that a routing system for electrical impulses. It is not like the current generation of ECUs that rely on chips to do the thinking.If you want a simple simily, think of it like this: Our ECUs are like a hand held calculator, while the current generation ECUs are laptop computers. Link to comment https://www.classiczcars.com/forums/topic/26493-78-280z-ecu-location/#findComment-231202 Share on other sites More sharing options...
October 10, 201113 yr comment_368829 THREAD REVIVE. have to say something tho.THIS is why i love this site. and not the other one. a standard reply from the other site would be "DO A GOOGLE SEARCH" Link to comment https://www.classiczcars.com/forums/topic/26493-78-280z-ecu-location/#findComment-368829 Share on other sites More sharing options...
