Anyone know where I can find an oil pan for sale . I've been searching, and so far all I've found are performance pans. I've seen 7, and 8 quart pans for between $550, and $750. I just need a stock pan that isn't pieced together with strips of aluminium.
OBX
https://www.classiczcars.com/forums/topic/26536-oil-pan/
The junkyards/pick-n-pulls often have two or three S30 and S31 in them. There is one or two at the Va. Beach PNBP right now. Anything from 70 to 83 will work. If you're interested, a friend has a long block (no ancillaries/intake/etc) N47/N42 L6 he'll let go for $75.00. It was a good running engine when pulled. He's trying to clear out the garage of excess parts/pieces. You need only drive up a short distance and get it. PM me if you'd like to do so.
https://www.classiczcars.com/forums/topic/26536-oil-pan/#findComment-231705
