Heloo,
I was searcing the forum and found no direct answer in regards to
this specific question for a 1977 280Z
Trying to see if a 14x8 rim with a -13 offset clear the front wheel well without
rubbing or the need for fender flares.
Also how will they fit the rear.
I used a tire calcutar on this website here
http://www.rims-n-tires.com/rt_specs.jsp
with the above demision with 14x7 Zero offset on 215/60/14 tires for the
first wheel on left which is what I have on front.
And compared them with 14x8 -13 offset on same tires for
the second wheel to the right.
Specs show my rims are 4 inch backspace aswell as the 14x8 -13's.
But my rims are 7 inches wide and stick out 3 inches from the mounting suface
why the 14x8 -13 stick out by 4 inches.
Will this incure any problems?
Will I need a thinner tire sidewall (not so bubbled out like my Goodyear Wingfoots)?
Thaynx again guys for any help once again.
~Z~
