June 7, 201311 yr comment_425075 The swap for the 73 240Z, 260Z & 280Z is something I'm going to be looking at in the future. I am interested in getting better integration with the intermittent function. At least I can test my theories out on the 240Z & 260Z. Link to comment https://www.classiczcars.com/forums/topic/26561-honda-wiper-motor-upgrade-for-the-240z/?&page=10#findComment-425075 Share on other sites More sharing options...
August 1, 201410 yr comment_452621 Hey all. This has been an exelent source of information for me so I thought I would share. I had a wiper motor failure and replaced it with a Cardone assembly. In the process of exchange I stumbled on a way of wiring this into my 72 without a relay and still maintains the park feature.5 prong Acura harness orientation: Looking at the plug-5--4--3- -2--1-2007 ACURA Integra DATSUN1: Low speed - Blue/ White2: High speed - Blue3: Ground - Black.4: 12v constant - Blue/ Red5: Intermittent - Jumper to #1 for Park signalBlue/Yellow is omitted from Datsun harness and not used.Blue wire on wiper motor needs to be cut and isolated on the switch side.Just needed to notch the shaft a little and it works flawless. Cost $72.00 Canadian taxed and delivered from E-Bay and there is very little wiring to do and no relay.Manufacturer Part Number: 76505-SR3-A01, 76505SR3A01 Reference Cardone Part Number: 43-1423 Edited August 1, 201410 yr by Jim_Reaper Forgot some information Link to comment https://www.classiczcars.com/forums/topic/26561-honda-wiper-motor-upgrade-for-the-240z/?&page=10#findComment-452621 Share on other sites More sharing options...
March 11, 20169 yr comment_488290 Where do I put the relay... Thanks Link to comment https://www.classiczcars.com/forums/topic/26561-honda-wiper-motor-upgrade-for-the-240z/?&page=10#findComment-488290 Share on other sites More sharing options...
September 28, 20168 yr comment_504033 On 3/11/2016 at 3:39 PM, Suleyman Tezgul said: Where do I put the relay... That's what I came looking for too, I searched but didn't really find what I was looking for. Please, someone correct me if I am wrong. I think you can pretty much mount it anywhere you want. I'm thinking that I may mount mine to the wiper motor with a hose clamp similar to how the original Z relay is done, inside the bag and out of sight for a more stock look. I got the 6-pin connector from Vintage Connections and plan to encase the new wire back to the Datsun side in heatshrink. My grommet is roached so this a good opportunity to replace it too. I am concerned a little about how hot the motor may get during use and melting the relay though, so I may engineer some kind of insulator/stand-off for it so it's not lying directly on the motor. Link to comment https://www.classiczcars.com/forums/topic/26561-honda-wiper-motor-upgrade-for-the-240z/?&page=10#findComment-504033 Share on other sites More sharing options...
May 30, 20177 yr comment_521983 Great article. Thought I would try to fix my original. turns out it was the copper commentator the brushes ride on was corroded. Also the plug...after sitting 32 years in a barn. Found this quick fix on the filthy plug. CLR soak. 20 min. Here is a before and after. Link to comment https://www.classiczcars.com/forums/topic/26561-honda-wiper-motor-upgrade-for-the-240z/?&page=10#findComment-521983 Share on other sites More sharing options...
June 13, 20177 yr comment_523013 If you can't get to a bone yard or pick a part...I found an awesome fix for slow early z wipper motors. First I cleaned inside the motor. Commentator and brushes. New grease where needed. And then bi-passed the LR power lead to motor with direct 12v from battery with 30/40 relay and 30a fuse. Works amazing...even on dry window. Edited June 13, 20177 yr by REMNANT Type error Link to comment https://www.classiczcars.com/forums/topic/26561-honda-wiper-motor-upgrade-for-the-240z/?&page=10#findComment-523013 Share on other sites More sharing options...
June 13, 20177 yr comment_523014 Total cost...$18.00 Link to comment https://www.classiczcars.com/forums/topic/26561-honda-wiper-motor-upgrade-for-the-240z/?&page=10#findComment-523014 Share on other sites More sharing options...
June 13, 20177 yr comment_523028 Love CLR, very versatile stuff. Link to comment https://www.classiczcars.com/forums/topic/26561-honda-wiper-motor-upgrade-for-the-240z/?&page=10#findComment-523028 Share on other sites More sharing options...
April 11, 20223 yr comment_639249 On 6/6/2013 at 6:53 PM, tamo3 said: Rain season is over here in CA, but I'm about to have wiper motor upgrade for my '75 280z. Following '75, '77, and '78 FSM and this thread, I drew diagram for wiring. Did this set up work. And what did you do with the unused blue/white and yellow wires from the oem harness? ( sorry that I'm 9 years late to the conversation :). ) Link to comment https://www.classiczcars.com/forums/topic/26561-honda-wiper-motor-upgrade-for-the-240z/?&page=10#findComment-639249 Share on other sites More sharing options...
April 11, 20223 yr comment_639252 41 minutes ago, Kentmo280z said: Did this set up work. And what did you do with the unused blue/white and yellow wires from the oem harness? ( sorry that I'm 9 years late to the conversation :). ) This may help you: https://forums.hybridz.org/topic/124734-understanding-the-260z-and-280z-wiper-circuit-reverse-polarity-park/ Link to comment https://www.classiczcars.com/forums/topic/26561-honda-wiper-motor-upgrade-for-the-240z/?&page=10#findComment-639252 Share on other sites More sharing options...
