Posted January 7, 200817 yr comment_233151 So while I'm working on rebuilding my engine I have been searching for r200s and a 5 speed. I know a guy with a lsd longnose r200 and have been trying to get A 5 SPEED from Miami to Ohio, but anyways, what is needed to put a longnose in my 73 240? Link to comment https://www.classiczcars.com/forums/topic/26678-conversion-to-longnose/ Share on other sites More sharing options...
January 7, 200817 yr Author comment_233153 also anyone know what kind of diff I would find on an 85 automatic 300zx Link to comment https://www.classiczcars.com/forums/topic/26678-conversion-to-longnose/#findComment-233153 Share on other sites More sharing options...
January 7, 200817 yr comment_233169 I believe it is going to be an R200, but you might have to contend with a different spline count. Not sure. Link to comment https://www.classiczcars.com/forums/topic/26678-conversion-to-longnose/#findComment-233169 Share on other sites More sharing options...
January 8, 200817 yr comment_233217 This may helphttp://www.zhome.com/ZCMnL/tech/GearRatios.html Link to comment https://www.classiczcars.com/forums/topic/26678-conversion-to-longnose/#findComment-233217 Share on other sites More sharing options...
January 8, 200817 yr comment_233224 Hi HxC240z:I do not know what a "long nose" r200 is. Can you provide the exact model and year car it was found in?The 300ZX's used the R200 - but with different flanges/yokes - not something that is a direct bolt-in, but can be done with enough money and a good rear end shop.See: http://www.zhome.com/ZCMnL/tech/R200.htmFWIW,Carl B. Link to comment https://www.classiczcars.com/forums/topic/26678-conversion-to-longnose/#findComment-233224 Share on other sites More sharing options...
January 8, 200817 yr comment_233287 Start here and keep searching...Lots of information on Hybridz on installing this rearend.http://forums.hybridz.org/showthread.php?t=103512&highlight=longnose Link to comment https://www.classiczcars.com/forums/topic/26678-conversion-to-longnose/#findComment-233287 Share on other sites More sharing options...
January 9, 200817 yr comment_233331 if you didn't know, there is a search tool, located in the blue colored bar of items (at the top area across the website), something like the 3rd one from the right...Use the search to answer your questions before posting your question. That's what is expected, and assumed everyone does, before anyone posts unknown info... Your questions have been answered many times...(other than 'longnose') what does this mean? never heard of the word in reference to a R200...beside the flanges and backing plates, an R200 is an R200, I thought.... good luck!!! Link to comment https://www.classiczcars.com/forums/topic/26678-conversion-to-longnose/#findComment-233331 Share on other sites More sharing options...
January 9, 200817 yr comment_233357 The shortnose R200 came in after 89. 240SX, Z32's, Q45's and many other Nissans have them. They can be installed in the S30 chassis but its kind of a PITA for no real appreciable gain (except the easy availability of viscous LSD). Here is my contribution: http://forums.hybridz.org/showthread.php?t=114798 Link to comment https://www.classiczcars.com/forums/topic/26678-conversion-to-longnose/#findComment-233357 Share on other sites More sharing options...
