Ive got a problem...
My L28 in my 240z is way off on timing..
The marks on the crank pulley have faded and i dont have the slightest idea on where it could be..
Now if im right, you can set it to TDC on #1 and mark it at 0 right??
Thanks for any info
hmmm faded? timing marks would almost have to be grounded off not to be present. If your crank pulley is in that bad of shape, you should take a visit to a junk yard and get another one.
Have you put your finger around the pully to feel for those marks? Could be gunk in the marks. Take a wire brush and clean'em up.. then take chalk and break out that timing gun. ;)
Saftey tip: Do this while the engine is off. ;)
alright... ill start brushing right now...
i did try to feel for them but no luck..
i am going to visit a junk yard this weekend for some tail lights, crank pulley and a e fan hopefully.
