best L28 head combination?
St.stephen
Personally I think I would go for the N-42. E-88 has smaller valves than the N-42 and N-47. I've heard stories about the heads with the exhaust liners deteriorating over time. Just a thought you might want to research before you buy anything. You will probably find the N-42 much easier to find than the N-47 as I believe the N-42 was used for a longer period of time.
Look on the Datsun Garage web-site for a good explanation of the pro's and con's for each particular head.
I agree as I have heard the same sort of feedback. I have all three head models as well as a host of Z parts (i have owned 5 and raped many more from the salvage yards)
so I'm looking for the best combinations for building my 260. I have the stock L26, but not the rear and trans so the dream of a numbers matching car for my tastes is shattered right now.
Here's what I have so far:
1" lowered Tokico struts and springs
1" sway bar up front
7/8" in rear
All urethane bushings
New fenders
Cross drilled rotors
4 piston calipors
72 Su's
L28 from 78 2+2, L28 from 76 coupe or L26
E88, N42, and N47 heads
New floors
4 core rad
all new brake lines
R180 and R200 rears
76 and 77 4 speeds, 78 2+2 5 speed
So I am really looking to bolt together the best powerplant and driveline combination I can come up keeping the car relatively stock Z
