Email logins are now active ×
Toyota Brakes, do I have them backwards?
red_dog007
Ok, so working on the brakes last night we got a lot done. New SS brake lines, repacked the hub, new rotors and while I was installing the Calipers I forgot which way they go in.
Is the bleed nipple on top, or is it on the bottom?
Also, I am having an issue hooking up the brake lines. The small "S" shaped brake line from the caliper to the mount on the strut, I can not get it to fit up to the new calipers. It is too short if the nipple is on the bottom and it is too long and the caliper piston is in the way if the nipple is up top. Is there something certain that can replace this "S" shaped brake line?
  • 5 weeks later...
I`m replacing the hard brake lines, just the shorter pieces, on the 240z coz it had SINGLE Flared COPPER lines(a "favorite" over here in the phil. coz its dirt-dirt cheap to buy and it can be flared at any auto supply store, and coz most of the population dont realize the DANGERS!). I just bought steel lines and had them cut it the right length and had them double flare it. I broke a cheap flaring tool(branded "General") trying to do the flairing. Then i`m just bending it by hand using some circular object, a pulley, tube,etc..I dont have a tube bender, thats why.
