Recently Browsing 0
I have been carefully working this last injector screw. Tighten a fraction, then loosen a fraction, used penatrating oil, etc etc. Been on this for a week. Finally most of the grip within the screw head is gone, so I can't even grip with the phillips screwdriver. This is in a tight spot. Any suggestions on removing this? I have a spare car with an intact fuel rail, injectors, and screws, etc, so if I have to break this injector I will, but I want to use that as a last resort!!
Thanks to any and all that can help.
https://www.classiczcars.com/forums/topic/26819-help-please-i-stripped-the-head-on-an-injector-screw/Share on other sites
