Email logins are now active ×
heater problems
rebelgt
My heat is broken on my 78 280z. I thought it was the valve on the outlet from the heater core at the water pump. I pulled the vacuum line and antifreeze poured out of the line. This doesn't seem right to me. Should I replace the valve? If not, does anyone have any thought as to what I should do next? what could be causing the vacuum line to be sucking up the coolant?
  • 1 month later...
  • 4 weeks later...
