Brake Light won't go OFF!
rhochisociety
I have a 1977 280Z, and it (or I rather) have an unusual problem. The red brake light indicator will not go off. But here is the kicker. When the parking brake is fully engaged the light is very red, release the parking brake and the brightness diminishes quite a bit (but it is still on). Any ideas would be appreciated.
Thanks,
Jim
Low fluid sounds right. Possibly, when you apply the parking brake you are augmenting the ground signal that the light is getting making it brighter. Is the same light used for a low fluid warning and a parking brake "on" indicator when the key is in the on position?
I had the same problem and it turned out to be the physical contact surface at the brake pedal switch . I just put a rubber cap on the pedal side.Maybe mine was to simple.
That's a different problem. They're talking about the brake warning light on the dash.
txz1956 is right, I had the same problem with my 77. I disconnected the relay under the seat and the light went out, but now of course it doesn't come on at all. But It'll do until I can replace it.
Where could I get a relay,are they still available?
Thanks,
Jim
Disconnecting the relay will make the light go out because the circuit is then open. That doesn't mean the relay is bad. Check the caps on the master cylinder that monitor the fluid level. They can also go bad.
More info, if I disconnect the relay under the passenger seat the light stays on, and there is wires on the master cylinder, but they are not connected to
anything, my mechanic could find nothing that they could connect to, maybe
this is the issue? If the wires were connected then that would solve the problem? Does anyone know where they go?
Thanks,
Jim
  • Who's Online   1 Member, 0 Anonymous, 735 Guests (See full list)
