Email logins are now active ×
L28/E31 with webbers, or N42 0r N46????
balaguy
ENGINE CASTING CODE
L24 (1970 240Z) # E31 (flattop pistons)
L24 ('71-73 240Z) # P30 (flattop pistons)
L26 ('74 260Z) # P30 (flattop pistons)
L28 ('75-80 280Z) # N42 (dished pistons)
L28 ('81-83 280ZX) # F54 (flattop/dished pistons, siamesed cylinders)
1970 through 1976 heads have square exhaust ports (E31, E88, N42)
1977-'83 heads use rounder, diamond shaped exhaust ports (N47, P79)
1981-'83 turbo heads have square exhaust ports (P90,P90a)
If you put those two lists together with information in the link in post #2 http://www.zhome.com/ZCMnL/tech/head.htm you can match up the years of each head with the blocks and get a little more info on each head. Bear in mind that this is for U.S. models. I know the model lineup differed a bit in Australia.
