Posted January 24, 200817 yr comment_235226 I have an automatic 260z. what is the best 5 speed tranny swap for it? Link to comment https://www.classiczcars.com/forums/topic/26869-5-speed-tranny-help/ Share on other sites More sharing options...
January 24, 200817 yr comment_235237 Depends on your definition of 'best'. I like the 81-83 ZX or 81-84 Maxima 5 speed because of the slightly higher 5th gear. Link to comment https://www.classiczcars.com/forums/topic/26869-5-speed-tranny-help/#findComment-235237 Share on other sites More sharing options...
January 25, 200817 yr Author comment_235324 just a really good 5 speed that would go in with the 260z. and what would the price be? Link to comment https://www.classiczcars.com/forums/topic/26869-5-speed-tranny-help/#findComment-235324 Share on other sites More sharing options...
January 25, 200817 yr comment_235328 The price depends on where you get it. I buy mine from the junkyards. I have paid as little as $45 for one, ten years ago, and as much as $125 last year. I replaced the bearings and seals and in a couple of them, the baulk rings. I always drains some of the gear lube into a container and check it's condition before I buy one. I look for metal shavings, chunks, etc. Check for play in the input/ouput shafts, shift mechanism, etc. I have purchased 5 or 6 trannies that way over the years and it has worked out well for me so far. Link to comment https://www.classiczcars.com/forums/topic/26869-5-speed-tranny-help/#findComment-235328 Share on other sites More sharing options...
January 25, 200817 yr Author comment_235329 how much would it cost to be put in? there is a z car guy around here that has alot of z cars and probably some old trannys Link to comment https://www.classiczcars.com/forums/topic/26869-5-speed-tranny-help/#findComment-235329 Share on other sites More sharing options...
January 25, 200817 yr comment_235333 To convert from automatic to a manual transmission takes more than just the transmission, you need a pile of other parts as well. Plus you'd better plan on at least 8 hours of shop time if you can't do the job yourself. Could be rather expensive to have to pay someone to do it.Here's a link to a write up I did on this conversion in an earlier 240Z. The process will be similar for your 260Z but some of the parts needed will be a bit different.http://classiczcars.com/forums/showthread.php?t=21274 Link to comment https://www.classiczcars.com/forums/topic/26869-5-speed-tranny-help/#findComment-235333 Share on other sites More sharing options...
January 25, 200817 yr Author comment_235335 how much will it cost to be put in you think? Link to comment https://www.classiczcars.com/forums/topic/26869-5-speed-tranny-help/#findComment-235335 Share on other sites More sharing options...
January 25, 200817 yr comment_235338 Not really sure. I do my own installations so I don't really have an idea of shop labor charges. Link to comment https://www.classiczcars.com/forums/topic/26869-5-speed-tranny-help/#findComment-235338 Share on other sites More sharing options...
January 25, 200817 yr comment_235343 Dustin, as I posted in your fusebox thread, please don't take this wrong, but your recent questions lead me to believe that you do not (or can not) do much work on your car yourself. We here on this forum can not give you accurate service quotes, as we're not the ones doing the work. If your car requires work that you can not do yourself, I'd recommend finding a local shop who can work on an older Datsun and get your quotes from them. If you need help finding a shop, perhaps some of our Texan members can help you with recommendations, if we knew where in Texas you are located.You'll find that a large majority of Z owners here do all their own service and repair. For that reason we really don't know how much labor costs. Link to comment https://www.classiczcars.com/forums/topic/26869-5-speed-tranny-help/#findComment-235343 Share on other sites More sharing options...
January 25, 200817 yr comment_235385 "$125 last year"I wish they still cost this much. At the Pick Your Part in Sun Valley, they wanted $175 for an 82 5-speed. Link to comment https://www.classiczcars.com/forums/topic/26869-5-speed-tranny-help/#findComment-235385 Share on other sites More sharing options...
January 25, 200817 yr comment_235393 cebu,Where in Texas are you? Link to comment https://www.classiczcars.com/forums/topic/26869-5-speed-tranny-help/#findComment-235393 Share on other sites More sharing options...
January 25, 200817 yr comment_235401 Shop rate is between $65 and $85 an hour. So take the higher number $85 x 8 Hours and that would be your labor rate alone. I think 8 hours is a conservative number so it could be more. For $700 for labor alone, I would happily continue to drive my automatic, shifting is overrated(joke, only kidding). Link to comment https://www.classiczcars.com/forums/topic/26869-5-speed-tranny-help/#findComment-235401 Share on other sites More sharing options...
