Posted February 2, 200817 yr comment_236157 After sitting with a full tank of gas for 6 months, the gas gauge quit working. The needle is dead at the total bottom.Is there an easy way to test the tank unit in the car, or the gauge in the car, to help determine which one is bad?Where does the gas gauge get the electricity to operate; from the tank or a feed under the dash?Thanks! Link to comment https://www.classiczcars.com/forums/topic/26947-gas-gaugetank-unit-quit-working-how-to-test-tank/ Share on other sites More sharing options...
February 2, 200817 yr comment_236163 I thought this question looked familiar.http://www.classiczcars.com/forums/showthread.php?t=29351http://www.classiczcars.com/forums/showthread.php?t=29352I'm not trying to be an a**, but you've got some of the information you require in your previous threads on the same topic. You might consider just adding on to your other threads with continuing questions. Doing so will help anyone who comes along later, since it is possible that they will have the same questions or similar problems.Good luck with your tank, tracking down gremlins can be an irritating process... Link to comment https://www.classiczcars.com/forums/topic/26947-gas-gaugetank-unit-quit-working-how-to-test-tank/#findComment-236163 Share on other sites More sharing options...
February 3, 200817 yr comment_236178 Nissanman and I both told you how to chck the gague . Did you try that?? If the gague didnt read full , then you either have a bad gague , loose or broken wire or a bad connection. Nuff said :disappoin Link to comment https://www.classiczcars.com/forums/topic/26947-gas-gaugetank-unit-quit-working-how-to-test-tank/#findComment-236178 Share on other sites More sharing options...
February 3, 200817 yr Author comment_236234 I'm sorry, I missed the replies to the right thread. The email didn't get to me that there had been a reply. Got the info now and will do the tests.Thanks!!! Link to comment https://www.classiczcars.com/forums/topic/26947-gas-gaugetank-unit-quit-working-how-to-test-tank/#findComment-236234 Share on other sites More sharing options...
