okay so im fixing up my 260, and i just finished replacing all of my freeze plugs, when i fill it up with coolant. Im about almost done filling it up and i hear a small dribble from underneath the car. Apparently i have a leak. Its not coming from my freeze plugs, and it doesnt look like its coming from the firewall or heater, the only place i can see where its wet is on the bottom of the transmission where its dripping off of. Does this sound like a cracked head or is there a freeze plug on the back of the block in the transmission? thanks for any views
https://www.classiczcars.com/forums/topic/26979-coolant-leak/
okay i took out my transmission, pulled of my clutch and removed my flywheel, and replaced the freeze plug, its a lot of work for a stupid leaking freeze plug. I also put in a new clutch kit while i was down there, now i just need to put the transmission back on
