Interior lighting upgrade for All Z's
Zs-ondabrain
I did the dome lamp upgrade from MSA a couple months ago that uses an LED bulb, I think it was $19-$0. Really did a good job of lighting up the interior with a nice white/bluish light. It was pretty simple, take out the stock bulb, put in the 1 inch square 9 LED replacement and stand back and be happy.
Like I already said before, The blue inverter box would easily slip into the dome light hole and be hidden up inside that roof support, so the only wires you'll see will be the white tube light wires. And those can easily be hidden with some black sleeving because the wires unplug from the inverter.
I also found out that the new tube lightscome on when the dome light switch is depressed. So they can be turned on at any time.
GNOSEZ....
The 3mm lights actually sit in an 11mm? protective tube. You're set.
  • 4 months later...
I know this is an older thread, but I gotta put my 2 cents in, since I don't want to see somebody's Z go up in flames.
These Cold Cathode lights have to have their voltage stepped up very high, thats what the box is for... well I have read many a post on computer moder forums of those boxes going up in Smoke and Flames! so If you do attempt this Please! buy the higher quality name brand ones, not the cheapies.
I think the High brightness LED sounds like a Much better idea, just for the safety standpoint.
