Posted February 6, 200817 yr comment_236567 I need to sort out a brake booster, master cylinder that will fit my firewall holes and run the R32 GTR front brakes and 300zx rears.SWR have informned me that I could use a 240z booster with a 280zx vertical mount master cyl 15/16 ratio and that this would be fine. Hoppers stoppers have recommended using a late 70's booster 1inch master cylinder from a Patrol. They say this fits straight onto 120y's 200b's but they are unsure if it will fit the 240K.Any ideas which kit will be best or any better ideas to sort the issue out please let me knowCheers Andrew Link to comment https://www.classiczcars.com/forums/topic/26990-brake-booster-master-cyl-upgrade/ Share on other sites More sharing options...
December 14, 200816 yr comment_268902 hey, any word on the Brake booster/master cyl upgrade? I've got a GC111 and I'm trying to upgrade my wheels before leave Japan in a year. Link to comment https://www.classiczcars.com/forums/topic/26990-brake-booster-master-cyl-upgrade/#findComment-268902 Share on other sites More sharing options...
December 20, 200816 yr Author comment_269347 I ended up fitting a R34 1inch master/booster and drilling holes into the firewall. It's easy to drill through the firewall but hard to custom modify the inside steering support brace to make sure the booster has something other than the firewall to hold to.I've been told that there is a 240z booster that will fit the std hole size and can also have a 1 inch master attached.Are you trying to upgrade to a 1 inch master to run bigger brakes?Do you know of any C110 fender mirrors for sale? Link to comment https://www.classiczcars.com/forums/topic/26990-brake-booster-master-cyl-upgrade/#findComment-269347 Share on other sites More sharing options...
January 28, 200916 yr comment_272332 I used a DR30 1" M/C and a DR30 10" booster.. there was a little messing around, but it fitted well (just hard to find them in OZ) Link to comment https://www.classiczcars.com/forums/topic/26990-brake-booster-master-cyl-upgrade/#findComment-272332 Share on other sites More sharing options...
February 8, 200916 yr comment_273568 I ended up fitting a R34 1inch master/booster and drilling holes into the firewall. It's easy to drill through the firewall but hard to custom modify the inside steering support brace to make sure the booster has something other than the firewall to hold to.I've been told that there is a 240z booster that will fit the std hole size and can also have a 1 inch master attached.Are you trying to upgrade to a 1 inch master to run bigger brakes?Do you know of any C110 fender mirrors for sale?I'm just trying to through on some 4 pot R32 brakes and will probably leave the rear stock drums. I don't plan on racing so, I think the 4 pots will be good. Do you know If I need a bigger booster for em, or should I stick to the stock ones? What kind of suspension do you have? I could get those mirrors here on yahoo auction. Link to comment https://www.classiczcars.com/forums/topic/26990-brake-booster-master-cyl-upgrade/#findComment-273568 Share on other sites More sharing options...
February 15, 200916 yr Author comment_274341 You'll need a bigger booster and a 1 inch master cylinder to run the 4 pot r32 brakes.The suspension in the convertible is z32 rear cradle and r31 front crossmember. I'll be upgrading to s14 struts and lower control arms shortly to increase the front track.Can you let me know what the mirrors go for in Japan?Cheers Link to comment https://www.classiczcars.com/forums/topic/26990-brake-booster-master-cyl-upgrade/#findComment-274341 Share on other sites More sharing options...
March 5, 200916 yr comment_276356 The mirrors over here on yahoo auction japan I can get for around 100.00. At least, that is what the starting bid is. Link to comment https://www.classiczcars.com/forums/topic/26990-brake-booster-master-cyl-upgrade/#findComment-276356 Share on other sites More sharing options...
March 7, 200916 yr comment_276594 will a 280z 8 1/2" Diameter Booster fit on the 240k? Link to comment https://www.classiczcars.com/forums/topic/26990-brake-booster-master-cyl-upgrade/#findComment-276594 Share on other sites More sharing options...
April 2, 200915 yr Author comment_279486 I don't know the answer to the booster issue, it would be best to take your one off make a template for the holes and take it into a wreckers to match it up.Would you be able to bid on some mirrors for me? I could transfer some cash to your bank or paypal account, whatever is easier for you.Cheers Andrew Link to comment https://www.classiczcars.com/forums/topic/26990-brake-booster-master-cyl-upgrade/#findComment-279486 Share on other sites More sharing options...
April 2, 200915 yr comment_279488 similarly, i would love to get my hands on some 240Z guard mirrors Link to comment https://www.classiczcars.com/forums/topic/26990-brake-booster-master-cyl-upgrade/#findComment-279488 Share on other sites More sharing options...
October 23, 200915 yr comment_298279 Tyrone, to answer your question the 280z booster will fit in a C110 chassis (just barely touching the clutch master cylinder) but I had to change the mounting plate that goes to the back of the booster and lengthen the rod that goes to the brake pedal about 30mm if that sounds like something you're up to doing. Link to comment https://www.classiczcars.com/forums/topic/26990-brake-booster-master-cyl-upgrade/#findComment-298279 Share on other sites More sharing options...
October 25, 200915 yr comment_298428 just a random question, is the brake booster on the right hand side in the american cars?are there many differences with the left hand drive cars? Link to comment https://www.classiczcars.com/forums/topic/26990-brake-booster-master-cyl-upgrade/#findComment-298428 Share on other sites More sharing options...
