Posted February 6, 200817 yr comment_236608 I do not want to keep my originial dampers and springs. So i want te car to be low on the ground. I have some questions, as i am still new to Datsun.What is the original spring height front and rear?How low can i go while stil using 15 inch rims with not that fat tires, say 215/50/15I want the front to be lower on the ground than the rear but just a bit. Link to comment https://www.classiczcars.com/forums/topic/26996-lowering-information-needed/ Share on other sites More sharing options...
February 7, 200817 yr comment_236617 I don't know the exact length of stock springs, but I think you probably want to go with an adjustable coilover setup so that you can decide your own ride height. If you go real low you will have to section your struts as well.If you search you will plenty of information on lowering your car. Here's a good start:http://classiczcars.com/forums/showthread.php?t=21460 Link to comment https://www.classiczcars.com/forums/topic/26996-lowering-information-needed/#findComment-236617 Share on other sites More sharing options...
February 8, 200817 yr Author comment_236801 Thanks for the information i used the search allready..but couldn't find everything i wanted. I do not want an adjustable setup. Only a bit lower to the ground with stiffer schoks and springs. Link to comment https://www.classiczcars.com/forums/topic/26996-lowering-information-needed/#findComment-236801 Share on other sites More sharing options...
February 8, 200817 yr comment_236802 Motorsport Auto http://www.zcarparts.com has a good selection. I would recommend Tokico Illumina shocks to tune your ride. Link to comment https://www.classiczcars.com/forums/topic/26996-lowering-information-needed/#findComment-236802 Share on other sites More sharing options...
February 13, 200817 yr comment_236939 I just changed out the stock struts and springs on my 260Z for a Tokico kit including springs and Tokico HP strut cartridges. Total drop was 2" in the front, 1.5" in the rear. I am VERY happy with the setup, and the kit cost only about $350 on Ebay from seller jdmwerks, who I recommend highly (with the only caveat being they are lousy at communication). Great value. This will totally transform your car's handling if you are coming off stock suspension. Definitely a harsher ride, but well worth it (at least to me). Link to comment https://www.classiczcars.com/forums/topic/26996-lowering-information-needed/#findComment-236939 Share on other sites More sharing options...
February 13, 200817 yr comment_236958 i went with a set of Tokico struts and springs also from EBay. the car looks alot better, and the ride is not too harsh. i did go back and add bump steer spacers to re align the correct height on the steering and that helped with the cornering. you might find they offer free shipping, like me which makes this an even sweeter deal. Link to comment https://www.classiczcars.com/forums/topic/26996-lowering-information-needed/#findComment-236958 Share on other sites More sharing options...
February 13, 200817 yr comment_236973 I haven't done this yet, but know someone who has, and have ridden in his car, but I like it a lot. He went with the eibach springs and the konig struts. Total over all lowering is 1", and it handles nice and smooth with a stiff suspension. Link to comment https://www.classiczcars.com/forums/topic/26996-lowering-information-needed/#findComment-236973 Share on other sites More sharing options...
February 13, 200817 yr comment_237003 justinr54321 said: I haven't done this yet, but know someone who has, and have ridden in his car, but I like it a lot. He went with the eibach springs and the konig struts. Total over all lowering is 1", and it handles nice and smooth with a stiff suspension.If you're talking about mine, I actually went with KYB struts.Dave. Link to comment https://www.classiczcars.com/forums/topic/26996-lowering-information-needed/#findComment-237003 Share on other sites More sharing options...
February 13, 200817 yr comment_237004 For what it's worth, I have the Eibach springs with Tokico HPs...I originally installed KYB Gas-just struts, but found it did not lower the car as expected.More than pleased with the ride and handling as it sits...GWGarrard Link to comment https://www.classiczcars.com/forums/topic/26996-lowering-information-needed/#findComment-237004 Share on other sites More sharing options...
February 13, 200817 yr comment_237008 i recomend you to get the "how to hotrod and race your datsun" book, there is spring lenght, diameter and spring rate.personally i would go for coilovers, you don't pay that much more and you get alot more for the bucks.Chris Link to comment https://www.classiczcars.com/forums/topic/26996-lowering-information-needed/#findComment-237008 Share on other sites More sharing options...
February 14, 200817 yr comment_237045 Zs-ondabrain said: If you're talking about mine, I actually went with KYB struts.Dave.:stupid:duh, yea I was talking about yours. I was more asleep when I wrote that up.:paranoid: Link to comment https://www.classiczcars.com/forums/topic/26996-lowering-information-needed/#findComment-237045 Share on other sites More sharing options...
February 14, 200817 yr Author comment_237053 Curtis240Z said: Motorsport Auto http://www.zcarparts.com has a good selection. I would recommend Tokico Illumina shocks to tune your ride.Yes, i think i will go for that one :classic: Link to comment https://www.classiczcars.com/forums/topic/26996-lowering-information-needed/#findComment-237053 Share on other sites More sharing options...
