Posted February 6, 200817 yr comment_236610 Can Anyone Tell Me The Casting Numbers On The 2.4 Cranks And The 2.8 Cranks... P30 Is A 2.4....anymore?????,what Crank Is A E3141???2.4 Or 2.8??? After All These Years Around Nissan's I Just Can't Remember...forgot To Tag All My Cranks...thanks Nissanzracer Link to comment https://www.classiczcars.com/forums/topic/26997-crankshaft-casting-numbers/ Share on other sites More sharing options...
February 7, 200817 yr comment_236619 Couldn't you tell by the stroke length? A 2.4 has a stroke of 72.7mm, the 2.6/2.8 is 79. Only 5mm, but it should be detectable.Besides, aren't crank shafts forged, not cast? Link to comment https://www.classiczcars.com/forums/topic/26997-crankshaft-casting-numbers/#findComment-236619 Share on other sites More sharing options...
February 7, 200817 yr comment_236628 yeah, they are forged, but they still have the numbers stamped into them so i suppose they can be casting numbers?the human eye can see very small differences in size. Just set the crankshafts next to each other and i'm sure you'll be able to see the difference between them pretty quickly. Link to comment https://www.classiczcars.com/forums/topic/26997-crankshaft-casting-numbers/#findComment-236628 Share on other sites More sharing options...
February 7, 200817 yr Author comment_236697 yes..i can check stroke.....i thought i could save time and see what you folks really know!!!!,by the way....the numbers are called "casting numbers",come on...you folks must be no different then the smart mouthed behind the keyboard types!!!!,if you can't answer the question!!!don't!!!,i really think all you people want to do is look at picture's!!!!!!!!!!!!!!!!!!!!!!!!!!,get a life!!!!! Link to comment https://www.classiczcars.com/forums/topic/26997-crankshaft-casting-numbers/#findComment-236697 Share on other sites More sharing options...
February 8, 200817 yr comment_236762 Get off the computer and go into your shed and check for yourself mate!!!Don't slag off on others because you're too lazy. Link to comment https://www.classiczcars.com/forums/topic/26997-crankshaft-casting-numbers/#findComment-236762 Share on other sites More sharing options...
February 8, 200817 yr comment_236779 To steal a laugh from Steve Martin "Well excuse me!".Seriously, this board gets a lot of traffic. If no one replies to your topic for a full day it will be pushed off of the front page and never be seen by anyone who might have the answer you are looking to find.Better to get a couple of snide remarks that bump your topic back onto the active page, than to miss the chance of someone who actually knows the answer never seeing your question. Link to comment https://www.classiczcars.com/forums/topic/26997-crankshaft-casting-numbers/#findComment-236779 Share on other sites More sharing options...
