Posted February 7, 200817 yr comment_236675 Hello, all.I have a pretty simple question. What is the difference between the L28 and L28E engine and which do I have?The VIN of my 78 280z is HLS30467776.I have a set of gaskets and seals that fit the 1978-1980 L28E engine. IF it turns out I have an L28 engine, will these gaskets and seals fit mine also?Thank you. Link to comment https://www.classiczcars.com/forums/topic/27003-l28-vs-l28e-engines/ Share on other sites More sharing options...
February 7, 200817 yr comment_236677 The "E" is for Electronic Fuel Injection. All L28's in the 280Z's and 280ZX's came from the factory with Electronic Fuel Injection. So your L28 is actually an L28E.FWIW,Carl B. Link to comment https://www.classiczcars.com/forums/topic/27003-l28-vs-l28e-engines/#findComment-236677 Share on other sites More sharing options...
