I removed my hood to have it resprayed last week. I observed that one hinge is not as tight as the other. There is some play as if the rivets would be loose but they are tight. I can plat sideways with the hinge part that connect to the hood.
Is there a way to fix this hinge looseness?
https://www.classiczcars.com/forums/topic/27085-hood-hinges/
Certainly is:)
It is called FBH, a Flamin' Big Hammer.
Those rivets were probably whacked with a hydraulic press when the hinge was assembled so try it again.
Back up the rivet with an anvil or another hammer head.
Or you could try squeezing them in a bench vice:cheeky:
The term in the U.S. of A. is B.F.H.; as in Big F"reaking" Hammer, but the use is the same.
You know how you Oz types refer to a Hood as a Bonnet? Well, how do gang members in Australia refer to their home turf?
Just asking...
E
