Email logins are now active ×
June 1973 240z - E12-80 distributor - car died, won't start
EricB
I take back what I said
No spark at sparkplug
0.5 volt at + coil when key is in ON & START positions
Just picked up another spare E12-80 at junkyard
Going home to try it out
bad/mixed up connections, bad ignition switch or relay ??? ... you should have 12 volt with ignition switch ON and 12 volt with ignition switch START, as the Blaster uses 12V as I recall...
BTW - many people are using the GM ignition module - far far less expensive than the NISSAN OEM part... and available at any Auto Parts Store..
Do you have a picture of the set-up/wiring?
Carl B.
Gary
Jim
Should I run 12v direct from battery to coil & bypass my stock wiring for now?
If I burnt out my E12-80 module after running the Blaster2 coil for several years it would be weird there's something all of a sudden wrong w/ the wiring right?
Gary thanks for talking to Kim B. I think I used a Msd coil because Zcargarage liked it so many years ago...
Z is running.
12v from battery straight to coil + did start the car
I found that a connection for GW & BW was loose & causing the problem
Also think that my distributor had some issues itself, shaft is loose & shows signs of having wobbled & caused uneven wear. Don't know yet if it's E12-80 is dead too
Will check that next
Thanks for everyone's help
-e
