February 20, 200817 yr comment_237897 I take back what I said No spark at sparkplug0.5 volt at + coil when key is in ON & START positionsJust picked up another spare E12-80 at junkyardGoing home to try it outbad/mixed up connections, bad ignition switch or relay ??? ... you should have 12 volt with ignition switch ON and 12 volt with ignition switch START, as the Blaster uses 12V as I recall...BTW - many people are using the GM ignition module - far far less expensive than the NISSAN OEM part... and available at any Auto Parts Store..Do you have a picture of the set-up/wiring?Carl B. Link to comment https://www.classiczcars.com/forums/topic/27110-june-1973-240z-e12-80-distributor-car-died-wont-start/?&page=2#findComment-237897 Share on other sites More sharing options...
February 20, 200817 yr Author comment_237910 GaryJimShould I run 12v direct from battery to coil & bypass my stock wiring for now?If I burnt out my E12-80 module after running the Blaster2 coil for several years it would be weird there's something all of a sudden wrong w/ the wiring right?Gary thanks for talking to Kim B. I think I used a Msd coil because Zcargarage liked it so many years ago... Link to comment https://www.classiczcars.com/forums/topic/27110-june-1973-240z-e12-80-distributor-car-died-wont-start/?&page=2#findComment-237910 Share on other sites More sharing options...
February 20, 200817 yr Author comment_237998 Z is running.12v from battery straight to coil + did start the carI found that a connection for GW & BW was loose & causing the problemAlso think that my distributor had some issues itself, shaft is loose & shows signs of having wobbled & caused uneven wear. Don't know yet if it's E12-80 is dead tooWill check that nextThanks for everyone's help-e Link to comment https://www.classiczcars.com/forums/topic/27110-june-1973-240z-e12-80-distributor-car-died-wont-start/?&page=2#findComment-237998 Share on other sites More sharing options...
February 20, 200817 yr comment_238001 Thanks for the feeback Eric... good to know you located the problemFWIW,Carl B. Link to comment https://www.classiczcars.com/forums/topic/27110-june-1973-240z-e12-80-distributor-car-died-wont-start/?&page=2#findComment-238001 Share on other sites More sharing options...
