I was gonna give my car a tune up today only to find out that 3 of my plugs had oil on them. the other 3 were all black and sooty. Which means that its running too rich right? And the other 3 with oil means that my piston rings are worn right?
If so, which would be better to do:
get the old l24 engine fixed? or buy a newer l28? I would rather get the l24 fixed but if the cost is equal to getting an l28, might as well upgrade then.
https://www.classiczcars.com/forums/topic/27117-to-fix-or-not-to-fix/
.....I understand the temptation in upgrading to an L28. But, why not consider sticking with the L24? More and more 240's are no longer equipped with the standard L24. It's not a bad thing as there are advantages to this. However, I think it would be cool to preserve that original sort of aesthetic.....mechanically speaking that is. Then again, $$$ talks.
It's always nice to be able to say your car is 100% stock knowing this to be true in the back of your mind. If you do opt for the L-28 be sure to keep the L24 just in case you want to revert. I had an L-28 w/ SU's as a "temporary" five year motor. (It only cost $125.00!!) It pulled great but top end performance suffered due to poor breathing from the SU's. Looked like someone else bored my SU's a tad too.
It's also nice to have a spare motor, radiator, etc, etc.
yeah, I'd do a compression test then go from there. I THOUGHT my car was burning oil because it was smoking (and it looked like oil smoke) and when i pulled the plugs they were a nasty black, well I also found out my car was running stupidly rich. I also thought that my plugs were wet with oil, but once i fixed the stupidly rich problem, no smoke, no wet plugs.
i cleaned the spark plugs and then leaned out the carbs a little bit. then i let it run for a bit and checked the plugs. the plugs where still a tad sooty but leaning it out did help. BUT...now when i drive the car, it really struggles uphill and i can't rev pas 2500 rpm without it gurgling and coughing. :angry: still haven't got a compression test yet. is it easy to do? if so, i'll just buy a kit and do it myself.
When you started this thread you mentioned that you were about to give the car a tune up. That is still a good place to start. Your timing may be off or you might need new plugs, cap, rotor, points, etc. A compression test is easy to do if you have the tool. Here's an example available at Sears:
http://www.sears.com/shc/s/p_10153_12605_00947089000P
