Posted February 20, 200817 yr comment_237919 What do I do..ahh..should i just take everything apart and fully sand blast and undercoat the whole thing??? :sleepy: ahh it crawled up to my engine block!! help!! My car is slowly dying... what should I do?!?!?!? Link to comment https://www.classiczcars.com/forums/topic/27134-ah-look-whats-under-neath-my-car/ Share on other sites More sharing options...
February 20, 200817 yr comment_237923 man it looks like it was parked on a boat ramp or a salt lake.I hope you really love it,lotsof tme and money ,if you did,nt love your zed you woud,nt be here, Link to comment https://www.classiczcars.com/forums/topic/27134-ah-look-whats-under-neath-my-car/#findComment-237923 Share on other sites More sharing options...
February 20, 200817 yr comment_237928 Yes -if you plan to keep it for a long time - take it all apart, put in on a rotisserie and strip the undercarriage down. Metal patch any area that is rusted, reseal any seams that need it. Then prime, POR-15 it and paint body color.Actually, looking past the dirt and grime - it looks to be in fairly good condition.If your going to go to all that trouble - make sure you take everything off that isn't welded on.FWIW,Carl B. Link to comment https://www.classiczcars.com/forums/topic/27134-ah-look-whats-under-neath-my-car/#findComment-237928 Share on other sites More sharing options...
February 20, 200817 yr comment_237939 There will never be a better time to save that car than now. Link to comment https://www.classiczcars.com/forums/topic/27134-ah-look-whats-under-neath-my-car/#findComment-237939 Share on other sites More sharing options...
February 20, 200817 yr comment_237941 You have a G-clamp to hold the exhaust pipe in place to the A arm???! Bet thats noisy.Replace the rubber strap hanger thing. Link to comment https://www.classiczcars.com/forums/topic/27134-ah-look-whats-under-neath-my-car/#findComment-237941 Share on other sites More sharing options...
February 20, 200817 yr comment_237942 Holy cow batman!! That certainly isn't a Southern California car is it? Looks like it's been around the world under water.Lots of work involved in getting the corrosion shut down and structural issues taken care of. Link to comment https://www.classiczcars.com/forums/topic/27134-ah-look-whats-under-neath-my-car/#findComment-237942 Share on other sites More sharing options...
February 20, 200817 yr comment_237949 Carl Beck said: ......it looks to be in fairly good condition.Same pictures the rest of us are seeing? Link to comment https://www.classiczcars.com/forums/topic/27134-ah-look-whats-under-neath-my-car/#findComment-237949 Share on other sites More sharing options...
February 20, 200817 yr comment_237952 Powdercoating everything on mine. Came out really nice and I believe it is worth it. Still have another trip to make which will include the transmission and differential cases along with many other parts. 77 280Z http://s38.photobucket.com/albums/e106/babry27/77%20Datsun%20Restoration/?start=all Link to comment https://www.classiczcars.com/forums/topic/27134-ah-look-whats-under-neath-my-car/#findComment-237952 Share on other sites More sharing options...
February 20, 200817 yr comment_237957 sblake01 said: Same pictures the rest of us are seeing?For Southern California, that car is nearly a disaster. Are they salting the roads up to Big Bear?For the East Coast and Snow Belt, that's mild. Heck, I looked at this one kid's 240Z when I lived in Virginia. Apparently a previous owner lived in Chicago. I think there was more fiberglass than steel on the underside of that car. I'm not sure what the frame rails connected to. Link to comment https://www.classiczcars.com/forums/topic/27134-ah-look-whats-under-neath-my-car/#findComment-237957 Share on other sites More sharing options...
February 20, 200817 yr comment_237961 I don't know how far you would like to take this car, but at the very least you should ensure it is, first safe, and second dependable. You have a better idea of the true condition of the underbody, because in the pictures we are seeing the remants of a previous owners rattle can work and a rainbow of corrosion. The best way to check the integrity of the front frame rails and shell is to clean it up and then evaluate it. I'm also looking past the crusty surface, maybe optomisticaly, but a judgment from just these pics can't be made with any degree of accuracy. I would at least pull the motor allowing you easier access and better attention to detail. Start cleaning, scraping, wire wheeling, sanding and use whatever other means you have at your disposal. Then put up some more pics, but by the time you have done this it will be obvious to you what you need to do. The good thing about this aproach is, it doesn't cost you much, you will become familiar with the car and be able to come up with a game plan. Link to comment https://www.classiczcars.com/forums/topic/27134-ah-look-whats-under-neath-my-car/#findComment-237961 Share on other sites More sharing options...
February 20, 200817 yr comment_237962 sblake01 said: Same pictures the rest of us are seeing?The back underside looks better than the front I believe is what he's saying.Yo Surf, was the front half of the Z nosed in a mud hole or puddle bychance? Seems like the engine block appears to have a water line where the corrosion ends or (comes up to) about the top of the oil filter.Actually where did you find it, that might help?~Z~ Link to comment https://www.classiczcars.com/forums/topic/27134-ah-look-whats-under-neath-my-car/#findComment-237962 Share on other sites More sharing options...
February 20, 200817 yr comment_237969 barby27 said: Powdercoating everything on mine. Came out really nice and I believe it is worth it. Still have another trip to make which will include the transmission and differential cases along with many other parts. 77 280Z http://s38.photobucket.com/albums/e106/babry27/77%20Datsun%20Restoration/?start=all barby27, if you don't mind me asking where did you get all the powder coating done at? Was the place you had the work done very expensive? Have you had any frame rail or floorboard(s) redone? I am just getting my "72" out of a very long storage and am in need of some direction of reputable places to seek work, information, and help. Thanks in advance. You can PM me if you want..... P.S. Very nice job on the powder coating of your Z parts. They look fantastic…. P.S.S Sorry for the temp hyjack Surfsup.... Link to comment https://www.classiczcars.com/forums/topic/27134-ah-look-whats-under-neath-my-car/#findComment-237969 Share on other sites More sharing options...
