June 10, 200816 yr comment_250358 I know someone with stub axles. Shoot me a PM. Link to comment https://www.classiczcars.com/forums/topic/27225-snapped-an-axle/?&page=2#findComment-250358 Share on other sites More sharing options...
June 11, 200816 yr comment_250410 "If the stub axle breaks right under the stub axle retaining nut, the nut was most likely cross threaded when last installed" - Or looseThe axle I found was genuine Nissan. I pressed the bearings on it and tapped it back into place. The locknut must have been loose because now, after I torqued it down, the clunk when I let out the clutch is gone!!. Oh well, I should have tightened it when I heard the clunk. Link to comment https://www.classiczcars.com/forums/topic/27225-snapped-an-axle/?&page=2#findComment-250410 Share on other sites More sharing options...
