Hi Adrian:
I sent you and Mark an e-mail message. So the two of you could connect directly. If you didn't get it - let me know. I did get a response from Mark, and he has reviewed this thread... perhaps sent you an PM.
kind regards,
Carl
  • 2 years later...
Time to revive this ancient thread. After letting this car sit for 2 years, I started working on it last October. The last prior registration was 1987. I have done:
Refurbished gas tank
Changed fuel sensor
New upper water coupler, temp sensor, thermostat
Had radiator shop Frankenstein 2 bad stock radiators into 1 good one
Pulled out all aftermarket gauges
Changed oil pressure sensor
Replaced all rubber lines, vacuum and fuel
Fan belt
Starter
Battery and battery wires
NGK plugs and plug wires
Rebuilt dual point distributor (I had one lying about anyway)
Brakes: new pads and shoes
had rotors and drums turned
new master cylinder
front brake lines
brake fluid flush and bleed
Changed oil & filter
Air filter
Western wheel center lines with holes
Refinished steering wheel
Horn button
Choke knob
door lock knobs
Carbs - cleaned and replaced float bowl gaskets (these need rebuilt to work right)
It runs, but I need to fix the horn and turn signals, have carbs rebuilt and adjusted before it's road ready. It's registered and licensed with a historic plate.
I've attached some pics. Now its just too hot to work on a car so it's covered up and I'll hit it again in October when it cools off.
Re-reading this whole thread, I noticed I didn't leave the details of #7969:
Build date is 8/70, titled as a 71
Nissan 2400 valve cover
4 screw SU's
No heat riser or flap on the air cleaner
Used to have AC
Metal emblems, not plastic
Has the original emissions decal for the automatic trans under the hood
Ashtray and cigarette lighter in the automatic console
Speedometer starts at 20mph
Original tools, manual and warranty book with cards from the dealer
Tool boxes behind the seats
Vents on the hatch
The warranty book includes the details like orange exterior/black interior and auto trans.
