Posted March 13, 200817 yr comment_240461 Have replaced the rear brake cylinders on my "72. Is there any difference in the way to bleed the rear lines since the cylinders are empty of brake fluid? Do I also need to bleed the front lines since they were not desturbed? And should I adjust the parking brake before or after I bleed the brakes? Thanks. Link to comment https://www.classiczcars.com/forums/topic/27350-rear-brake-bleeding/ Share on other sites More sharing options...
March 13, 200817 yr Author comment_240538 Any thoughts? Link to comment https://www.classiczcars.com/forums/topic/27350-rear-brake-bleeding/#findComment-240538 Share on other sites More sharing options...
March 13, 200817 yr comment_240539 Unless the hydraulic fluid is less than 2 years old I would advise flushing and bleeding the entire brake system.It can be as simple as opening all the bleeder screws and letting the old fluid drain through while topping up the M/C with fresh fluid.When you see the new fluid emerging from the bleeders, close them off.You can then do a conventional bleed at each corner to ensure the absence of air bubbles.Rears first, longest line first, then fronts, longest line first.I would also suggest you adjust the Emergency Brake prior to bleeding the rears. Link to comment https://www.classiczcars.com/forums/topic/27350-rear-brake-bleeding/#findComment-240539 Share on other sites More sharing options...
March 25, 200817 yr comment_241839 ^^^ what Nissanman said ^^^This may help, as well:http://www.classiczcars.com/forums/showpost.php?p=197062&postcount=13 Link to comment https://www.classiczcars.com/forums/topic/27350-rear-brake-bleeding/#findComment-241839 Share on other sites More sharing options...
