Posted March 14, 200817 yr comment_240617 I'm working on a 78 280Z for a friend of mine and I need the rubber coupler for the steering column, this one seems very sloppy. Also the L/H strut is leaking, it needs new gland packing assy. ( has an oil seal & O'ring) I believe it is called. Will I need to get these through the dealer or does someone know of a private supplier to get the OEM parts. Thanks, pedro Link to comment https://www.classiczcars.com/forums/topic/27366-steering-coupler/ Share on other sites More sharing options...
March 14, 200817 yr comment_240618 The original couplers are not very stiff anyway, I recommend that you replace it with poly - bush kits are available through ebay or "Motorsport" (see the icon on the club's main page), you can buy it individually or as part of a kit. Link to comment https://www.classiczcars.com/forums/topic/27366-steering-coupler/#findComment-240618 Share on other sites More sharing options...
