Does anyone have the Nissan part no.'s for the 4x metal brake/fuel pipe clips and rubbers located along the tunnel and also the one located on the rear cross member ? Are these still available to order ? Thanks.
They are no longer available from Nissan. Well, that is what my local Nissan dealer said but they are very unhelpful. I made up new rubbers and steel clips. Didn't take too long to sort. Steel was galvanised sheet that I cut and shaped, primed and sprayed black.
The rear cross member rubber could be replaced with a hoses. End the lines above the diff and extend with fuel hose to the tank outlets.
My car doesn't have a vent return as does some HLS30's. Your being a HS30 shouldn't have a return vent if I'm correct. So all you will need to run is one large fuel feed, and two smaller lines, one for fuel return and one for the rear brake feed.
Just take into consideration that if you find a US supplier of the rubbers and clips that they may not fit your car. HLS30's have four lines down the tunnel to HS30's three. To accomadate the fourth line, Nissan may have made the brackets/clips and rubbers larger than those required for the three lines. Worth checking.
Have you found a source for engine bay fuel line rubbers that run along the frame rail?
