well, I am finally getting to the heart of my disappearing brake fluid problem on the 72 240z. Looking at the back tire I could see some residue on the back side of the drivers side rear wheel.
It's been several (over 12) years since I have worked on Drum brakes. The rubber line still appears nice and dry. I pulled the drum off and found the shoes and inside of the drum nice and soaked in brake fluid.
Anyway, I would still like to confirm with the community, I have a blown wheel cylinder. I had a similar problem in the late 80's (ugh) which turned out to be the steel line on the backing plate.. I can't remember if that leak made it all the way into the drum though.. Anyone agree or disagree?
Thanks in advance for your time..
https://www.classiczcars.com/forums/topic/27410-steel-line-or-wheel-cylinder/
