Email logins are now active ×
why!! does my 77 datsun 280z run to rich and flood out
nissan280z
Jonathan,
I think you need a bit more information on your situation before you can expect anyone to respond to your question. Also, we have a search function that is quite good at retreaving archived information!
Tom
I'm curious. You had a problem with the injectors not getting power. Apparently you've 'fixed' that if the car now 'runs to rich and floods out'. You never posted that you'd found the solution. What was your fix for the other problem? I only ask because it may have something to do with the present one. Oh, and ignore smokingwheels. Most people do.
hey nissan280z. I think 240zx is right about needing a little more info, but everyone is right about things to check. Corroded coolant temp sensor, mass air meter, fuel pressure regulator. these are all shots in the dark of course but in my experiance they have been good places to start.
If replacing the injectors makes things 'less rich, then it sounds like the injectors were stuck open (because of some crud on the needle?) and you chose a $400 cure instead of an $80 cleaning job.
Nillyjarrell-
280Zs didn't have a mass air meter. It's called an Air Flow Meter (AFM.) Wasn't the Mass Air Meter invented around 1995?
  • Who's Online   1 Member, 0 Anonymous, 510 Guests (See full list)
