Posted March 24, 200817 yr comment_241687 is the paint code on the black buck tag under the hood or elsewhere? Link to comment https://www.classiczcars.com/forums/topic/27495-paint-code-location/ Share on other sites More sharing options...
March 24, 200817 yr comment_241688 On 240z's it is on a foil sticker on the radiator support.-Mike Link to comment https://www.classiczcars.com/forums/topic/27495-paint-code-location/#findComment-241688 Share on other sites More sharing options...
March 24, 200817 yr comment_241700 On the 280z's it's on a paper sticker on the radiator support (passenger side). Link to comment https://www.classiczcars.com/forums/topic/27495-paint-code-location/#findComment-241700 Share on other sites More sharing options...
March 24, 200817 yr comment_241719 On the ZX (s130) it is a foil sticker on the radiator support, passenger side. Link to comment https://www.classiczcars.com/forums/topic/27495-paint-code-location/#findComment-241719 Share on other sites More sharing options...
March 25, 200817 yr comment_241729 On the 280z's it's on a paper sticker on the radiator support (passenger side).I have a 78 and mine is foil. Link to comment https://www.classiczcars.com/forums/topic/27495-paint-code-location/#findComment-241729 Share on other sites More sharing options...
March 25, 200817 yr comment_241731 I recall peeling mine off before getting my car painted. I could never read it since it had been painted over by a previous owner. Instead of paper or foil mine is more of a thin foil-looking plastic. Link to comment https://www.classiczcars.com/forums/topic/27495-paint-code-location/#findComment-241731 Share on other sites More sharing options...
March 25, 200817 yr comment_241733 I've always thought it would be cool if you could still get the stickers from Nissan with the original paint codes on them to replace your faded one. Link to comment https://www.classiczcars.com/forums/topic/27495-paint-code-location/#findComment-241733 Share on other sites More sharing options...
March 25, 200817 yr comment_241735 I've always thought it would be cool if you could still get the stickers from Nissan with the original paint codes on them to replace your faded one.You mean like ones that Norm in BC (zeddsaver.com) sells?http://www.zeddsaver.com/decals.html Link to comment https://www.classiczcars.com/forums/topic/27495-paint-code-location/#findComment-241735 Share on other sites More sharing options...
March 25, 200817 yr comment_241736 You mean like ones that Norm in BC (zeddsaver.com) sells?http://www.zeddsaver.com/decals.htmlOh wow, I've never even come across that site before. I should see about getting a new one for my car. Link to comment https://www.classiczcars.com/forums/topic/27495-paint-code-location/#findComment-241736 Share on other sites More sharing options...
March 25, 200817 yr comment_241737 His stickers are correct for a 70-76. They say 'PAINT AMINO ALKYD ENAMEL' across the bottom. 77-78 doesn't have that line across the bottom because 76 was the last year that type of paint was used. Link to comment https://www.classiczcars.com/forums/topic/27495-paint-code-location/#findComment-241737 Share on other sites More sharing options...
March 25, 200817 yr comment_241740 His stickers are correct for a 70-76. They say 'PAINT AMINO ALKYD ENAMEL' across the bottom. Actually - That isn't correct. I dropped him an e-mail to ask about that. He only shows a picture of ONE Paint Code Sticker... he MIGHT actually have two or more different ones. One might not however get that impression as he only asks that you specify the Paint Code. The sticker that says "AMINO ALKYD" would NOT be correct for Paint Code 901 for example, as it was a Metallic Color painted with Acryl Enamel (Acrylic). So - 76Datsun280Z should assure the Sticker he orders - has the right type of paint printed on it. Pictured below is the original paint code sticker from an 11/69 production 240-Z. FWIW, Carl B. Link to comment https://www.classiczcars.com/forums/topic/27495-paint-code-location/#findComment-241740 Share on other sites More sharing options...
March 25, 200817 yr comment_241741 Hmmm, he doesn't have the 517 listed on there for the 280z . Mine doesn't say what type of paint it uses either. http://img.photobucket.com/albums/v230/half_breed/My%20Z/DSC06847.jpg Link to comment https://www.classiczcars.com/forums/topic/27495-paint-code-location/#findComment-241741 Share on other sites More sharing options...
