Posted March 24, 200817 yr comment_241690 I recently replace my wiring harness and the connector for the tach is for a 4 wire tach. My old wire harness was for a 3 wire tach. Does anyone know which wires go where? I have seen pictures but can't really make them out. Any help would be greatly appreciated. Link to comment https://www.classiczcars.com/forums/topic/27496-3-wire-tach-question/ Share on other sites More sharing options...
March 24, 200817 yr comment_241694 Did you replace the entire harness? Engine and Rear components at the same time as the Dash? If not, you may have other problems other than the wrong tach.I don't recall anyone modifying a 3-wire tach to function in a 4 wire loom.Sorry.E Link to comment https://www.classiczcars.com/forums/topic/27496-3-wire-tach-question/#findComment-241694 Share on other sites More sharing options...
March 24, 200817 yr Author comment_241695 That's what I am afraid of. I am now trying to acquire another harness with the 3 wire connector. Link to comment https://www.classiczcars.com/forums/topic/27496-3-wire-tach-question/#findComment-241695 Share on other sites More sharing options...
March 24, 200817 yr comment_241704 Don't forget that it's a 3-part set. While you can make some things work, others require more work and effort than it's worth.You don't mention if you did replace all of them or just the dash one. If you replaced the set then just find a tach that works with the loom. If on the other hand just the one, then replace it.E Link to comment https://www.classiczcars.com/forums/topic/27496-3-wire-tach-question/#findComment-241704 Share on other sites More sharing options...
March 24, 200817 yr Author comment_241708 Yeah it was just the one. So I have put in my request to zbarn where I received the harness. Link to comment https://www.classiczcars.com/forums/topic/27496-3-wire-tach-question/#findComment-241708 Share on other sites More sharing options...
