Posted March 28, 200817 yr comment_242209 Hi Guys, I have a 78 280z 2+2 and recently I started to hear a strange noise coming from the engine compartment (high pitch screech ). It sound like a bad power steering unit, not that the my Z has one but, it comes and goes. This usually happens when in neutral and I rev the engine and as rpms go up it stops. It also, happens when I start driving from a standing position and I'm accelerating but once the clutch is fully engaged it stops. I've tried to isolate the noise but can't seem to find out where exactly it's coming from. If anyone has any thoughts I would appreciate the help. Regards, Rick Link to comment https://www.classiczcars.com/forums/topic/27539-strange-noise-from-engine-compartment/ Share on other sites More sharing options...
March 28, 200817 yr comment_242211 Have you checked drive belt tension? Link to comment https://www.classiczcars.com/forums/topic/27539-strange-noise-from-engine-compartment/#findComment-242211 Share on other sites More sharing options...
March 28, 200817 yr Author comment_242216 Yes, I have and actually replaced them. "I'm restoring my Z on part at a time"BTW, the noise was there before and still there.thanks Link to comment https://www.classiczcars.com/forums/topic/27539-strange-noise-from-engine-compartment/#findComment-242216 Share on other sites More sharing options...
March 28, 200817 yr comment_242221 Does it only happen when you have the clutch in? It might be something like the throwout bearing dying. Link to comment https://www.classiczcars.com/forums/topic/27539-strange-noise-from-engine-compartment/#findComment-242221 Share on other sites More sharing options...
March 28, 200817 yr Author comment_242223 Yes, and also when it's in neutral and I rev the engine, so I don't thik thats it.Thanks, Link to comment https://www.classiczcars.com/forums/topic/27539-strange-noise-from-engine-compartment/#findComment-242223 Share on other sites More sharing options...
March 28, 200817 yr comment_242224 It could be if the clutch is adjusted in such a way that the throwout bearing just touches the clutch when it's let out, I know mine makes a funny noise kind of like that but only when it's in neutral. It stops when I start moving. For me I think it's a bearing on my mainshaft. I probably need to change the oil in my transmission.but mines quiet. From what you describe it's quite a loud sound. is it? Link to comment https://www.classiczcars.com/forums/topic/27539-strange-noise-from-engine-compartment/#findComment-242224 Share on other sites More sharing options...
March 28, 200817 yr comment_242226 Do you have a cat and have you seen him lately? Link to comment https://www.classiczcars.com/forums/topic/27539-strange-noise-from-engine-compartment/#findComment-242226 Share on other sites More sharing options...
March 28, 200817 yr Author comment_242227 That's possible! here kitty, kitty, Link to comment https://www.classiczcars.com/forums/topic/27539-strange-noise-from-engine-compartment/#findComment-242227 Share on other sites More sharing options...
March 28, 200817 yr Author comment_242228 I'll post a sound bite this weekend. Link to comment https://www.classiczcars.com/forums/topic/27539-strange-noise-from-engine-compartment/#findComment-242228 Share on other sites More sharing options...
March 28, 200817 yr comment_242237 it could be the fan clutch, i had that problem and the belt needed to be tightened. here is the sound I had. Link to comment https://www.classiczcars.com/forums/topic/27539-strange-noise-from-engine-compartment/#findComment-242237 Share on other sites More sharing options...
March 28, 200817 yr comment_242241 I had a similar situation a couple years ago. For me, the noise was on and off for a bit, but progressed to a full time thing. Turned out to be bad idler pulleys. I too couldn't find the source of the noise and ended up taking the car to a Nissan dealer as the noise had passed bearable. Link to comment https://www.classiczcars.com/forums/topic/27539-strange-noise-from-engine-compartment/#findComment-242241 Share on other sites More sharing options...
March 29, 200817 yr comment_242244 Cornbreadxd said: it could be the fan clutch, i had that problem and the belt needed to be tightened. here is the sound I had. wow, that sounds horrible! I rebuilt my fan clutch not too long ago. The issue with mine is hardly noticable, but from what he's describing, it's a really loud sound like yours. Guess we just have to wait for a sound bite. Link to comment https://www.classiczcars.com/forums/topic/27539-strange-noise-from-engine-compartment/#findComment-242244 Share on other sites More sharing options...
