Posted March 29, 200817 yr comment_242308 Hi Guys its time for a clutch change, i put in a 5 speed from a 78 in it last summer and its slipping when i get on it, my 72 Z has original Racer brown cam mod, big exhaust no header, and the 5 speed. Its lowered, 36k original miles run hard when i drive it. Any advise on a stronger one and source for it will be appreciated. Link to comment https://www.classiczcars.com/forums/topic/27551-clutch-replacement-advise-72-modified-z/ Share on other sites More sharing options...
March 29, 200817 yr comment_242311 You do not need a stronger clutch, simply replace your worn out OE clutch. You are not making that much power. Link to comment https://www.classiczcars.com/forums/topic/27551-clutch-replacement-advise-72-modified-z/#findComment-242311 Share on other sites More sharing options...
March 30, 200817 yr Author comment_242354 should it be a 225 MM or larger? What brand are ypou guys using on higher HP? I am not sure why this one failed with under 1k miles on it. Link to comment https://www.classiczcars.com/forums/topic/27551-clutch-replacement-advise-72-modified-z/#findComment-242354 Share on other sites More sharing options...
March 30, 200817 yr comment_242366 I am using an ACT heavy duty pressure plate and ACT street disk. I am putting down around 320 ft-lbs to the wheels right now, and once I finish my meth injection setup (waiting for the tank), I should be around 360 ft-lbs to the wheels. Great engagement, not too harsh, though the pressure plate is a bit stiff.I am using the 240mm flywheel for my turbo setup. Link to comment https://www.classiczcars.com/forums/topic/27551-clutch-replacement-advise-72-modified-z/#findComment-242366 Share on other sites More sharing options...
March 30, 200817 yr Author comment_242427 where did you get it KTH? Link to comment https://www.classiczcars.com/forums/topic/27551-clutch-replacement-advise-72-modified-z/#findComment-242427 Share on other sites More sharing options...
March 30, 200817 yr comment_242457 http://forums.hybridz.org/showthread.php?t=117264&highlight=high+performance+clutchzdisease Link to comment https://www.classiczcars.com/forums/topic/27551-clutch-replacement-advise-72-modified-z/#findComment-242457 Share on other sites More sharing options...
