Email logins are now active ×
Horsepower Estimate
fixitman
In the early 80's I began the restoration of my first car, an early 1974 Datsun 260Z. Due to poor work by a restoration shop after the car was stolen, the project was put on hold for a few decades. Now, I expect the project to be completed in the late spring/early summer of this year. For the first time in 27 years, the engine came to life with a glorious song last week. I was wondering if the learned readers of this forum could estimate the engine horsepower and rear wheel horsepower from the following drive train description.
Air box: K&N Lamborghini 3-carb filter in aluminum housing with Mikuni air horns
Alternator: 60 amp
Camshaft: Racer Brown SS-54-110 – 236 degree duration at 0.025” lift with 0 lash, 110 degree lobe centers, and 0.480” lift net, and valve spring/retainer package
Carburetion: Mikuni triple side draft, 40PHH with 32mm chockes and custom balance tube
Cylinder head: Decked 0.020”
Bronze valve guides
280Z intake valves, 0.173” dia.
280Z exhaust valves
Valves and seats grinded
Built by Floyd Link, Torrance, CA
Exhaust:
Header: Euro Car Anti-Reversionary, 1 ½” dia. tubing, 3 into 2, 2 ¼” dia. collector outlet
System Dia.: 2 ¼”
Resonator: Borla resonator
Muffler: Borla turbo muffler
Ignition: New stock coil
New stock distributor
Taylor 8mm Spiro-Pro
NGK Iridium spark plugs
Oil pump: ZX-Turbo unit
Pistons: Datsun 0.040” over, flat top
Differential: R180 limited slip, 3.545 R&P set, Bob Sharp Racing spare
Transmission: 280Z 5-speed
Thanks for your help.
FixItMan
The block and head are the original that Datsun intended for this 260Z. I believe the compression ratio calculated out to 10.0 or a little higher. What is the proper tuning process? I'm assuming you mean on a chassis dyno at this point.
Did you notice the fuel rail? The original brackets have been reused with stainless steel tubing for the fuel return, fuel supply, vacuum and vapor purge. The PVC valve is installed under the carb heat shield and connects to the balance tube.
FixItMan
  • Who's Online   1 Member, 0 Anonymous, 307 Guests (See full list)
