Posted March 30, 200817 yr comment_242378 Hi Guys,I've installed my tripple DHLA40L Carbs recently. The motor is an L28 and in need of a rebuild in the near future, perhaps 6 to 12 months away at this point so I don't want to blow a heap of money getting them professionally set up on a dyno until after the rebuild. In the mean time I thought I would get them running as well as I could. My L28 is stock with elec dizzy, headers and 2 1/4" pipe with a hot dog and turbo flow muffler. The engine idles ok atm however running extremely rich. I've been using the Des Hammill book "How to tune Webers & Dellortos". Anyhow I've attached a spread sheet I hope to build on as I fumble my way through the world of tripple carbs. Please advise me of your tripple set up and have a look at my info todate correcting anything that might sound off. I know there are alot of variables depending on engine set up and driving style when it comes to tuning tripples but I'm just trying to get to a start point and then keep fine tuning. I hope to keep some mid range power rather than have a car that has to be driven around at 5500rpm every time I go down the street. Cheers,SulioTripple Carb Info Sheet.pdf Link to comment https://www.classiczcars.com/forums/topic/27557-dellorto-dhla40l-set-up-spreadsheet/ Share on other sites More sharing options...
March 30, 200817 yr Author comment_242397 ...updated sheet.Tripple Carb Info Sheet - updated 31 March 2008.pdf Link to comment https://www.classiczcars.com/forums/topic/27557-dellorto-dhla40l-set-up-spreadsheet/#findComment-242397 Share on other sites More sharing options...
May 24, 200816 yr Author comment_248643 ...updated sheetTripple Carb Info Sheet - updated 24 May 2008.pdf Link to comment https://www.classiczcars.com/forums/topic/27557-dellorto-dhla40l-set-up-spreadsheet/#findComment-248643 Share on other sites More sharing options...
December 31, 201113 yr comment_375864 what was your final setting once you got it dynoed and so on? ive been trying to work out jet sizes for my l28 with dhla40ls also. cheers:) Link to comment https://www.classiczcars.com/forums/topic/27557-dellorto-dhla40l-set-up-spreadsheet/#findComment-375864 Share on other sites More sharing options...
