Posted March 30, 200817 yr comment_242439 Got an '80 5-speed over a year ago when the 5-speed from a '78 gave up the ghost. I had problems getting it to go in to second and I'm curious if there are any known reliability problems with the 5-speeds out of the 80 model year.I checked he reservoir and it's full. I'm going to check the gear shift to see if it needs to be tightened etc. Last resort short of the transmission is the clutch slave cylinder...I'd really hate to eat another transmission after only about a year. Link to comment https://www.classiczcars.com/forums/topic/27563-known-problems-with-80-5-speeds/ Share on other sites More sharing options...
March 30, 200817 yr comment_242441 Sounds like the second gear syncho ring is worn to me. Not an uncommon problem with any used manual transmission, probably not year specific. When you consider how many miles most of these transmissions have on them by now, why should it surprise us?My '71 4 speed was the same way. I replaced all the synchro rings when I had it apart for bearing replacement, shifts into second (and all gears) beautifully now. Link to comment https://www.classiczcars.com/forums/topic/27563-known-problems-with-80-5-speeds/#findComment-242441 Share on other sites More sharing options...
March 30, 200817 yr Author comment_242444 Got a source for the synchro rings? Link to comment https://www.classiczcars.com/forums/topic/27563-known-problems-with-80-5-speeds/#findComment-242444 Share on other sites More sharing options...
March 30, 200817 yr comment_242447 I got mine at the dealer. I'm pretty certain that they are all the same, both four and five speeds. But disassembling a transmission is not for the faint of heart. Link to comment https://www.classiczcars.com/forums/topic/27563-known-problems-with-80-5-speeds/#findComment-242447 Share on other sites More sharing options...
March 30, 200817 yr comment_242450 Oh, I don't know. I've done a few of them. It's not the dissasembling that's not for the faint of heart, it's the reassembling! Link to comment https://www.classiczcars.com/forums/topic/27563-known-problems-with-80-5-speeds/#findComment-242450 Share on other sites More sharing options...
March 31, 200817 yr Author comment_242464 How is the '80 5-speed different, or is it, from the 5-speeds in the '78-'79s or the '81-'83s? Link to comment https://www.classiczcars.com/forums/topic/27563-known-problems-with-80-5-speeds/#findComment-242464 Share on other sites More sharing options...
March 31, 200817 yr comment_242473 The gear ratios are different, that is all. Check them out here:http://www.geocities.com/z_design_studio/transmission.htmlThat may have been the 100th time that link has been posted. Link to comment https://www.classiczcars.com/forums/topic/27563-known-problems-with-80-5-speeds/#findComment-242473 Share on other sites More sharing options...
March 31, 200817 yr comment_242479 My 1980 5pd has the same problem. I have to do a slow shift from 1 to 2nd, if I shift to fast it jams a bit. My friend, who runs a tranny shop, went through it for me and replaced a few bearings, said that the no 2 synchronizer was just a little worn, I wished now that I would have had him change it. Link to comment https://www.classiczcars.com/forums/topic/27563-known-problems-with-80-5-speeds/#findComment-242479 Share on other sites More sharing options...
March 31, 200817 yr comment_242484 The synchro ring is about $30. I routinely replace them just because whenever I have a transmission that far apart. Especially the first and second gear synchros, as those two get the bulk of the wear. Link to comment https://www.classiczcars.com/forums/topic/27563-known-problems-with-80-5-speeds/#findComment-242484 Share on other sites More sharing options...
March 31, 200817 yr comment_242487 I tend side with those that learn the hard way. Jon :stupid: Link to comment https://www.classiczcars.com/forums/topic/27563-known-problems-with-80-5-speeds/#findComment-242487 Share on other sites More sharing options...
March 31, 200817 yr Author comment_242509 The gear ratios are different, that is all. Check them out here:http://www.geocities.com/z_design_studio/transmission.htmlThat may have been the 100th time that link has been posted.I knew the ratios were different but I was told the exterior cases were different as well, that's in large part why I asked.I may just try to get a T-5 rebuilt and swap them, keeping this one as a spare. Link to comment https://www.classiczcars.com/forums/topic/27563-known-problems-with-80-5-speeds/#findComment-242509 Share on other sites More sharing options...
March 31, 200817 yr comment_242514 This pic shows the differences. Link to comment https://www.classiczcars.com/forums/topic/27563-known-problems-with-80-5-speeds/#findComment-242514 Share on other sites More sharing options...
