Email logins are now active ×
help
Don Young
I am new at this. I have a1988 300zx turbo My problem is coolant went all over my motor and know all my dash red lights are on all the time, Battery door coolant brake and brake stop light. What can I do . Thanks for the help:disappoin:
Did you have a broken hose or something?
Someone on the site may know specifics about the 300ZX, but most people here are only 1st generation Z people.
I guess that you might have blown a fuse, or a fusable link. You might have lost a ground...
Or you may have more serious problems. Either find a manual for that car, or find a mechanic. Those are your best options.
You may also have better luck getting answers about your car at one of these sites:
http://www.300zxclub.com/
http://www.z31.com/
Good luck!
try z31.com they are all z31 guys. hybridz might be worth a try also. you shorted something out. pull all the connectors you can find in the engine bay and blow them out with air make sure they are dry. You can get the alternator tested cause on a 280zx if you lose the alternator all the dash lights come on nissan may have done the same with the z31. Replace radiator hoses before they blow up. Friend of mine let his go on his 86 but he didn't get fluid all over everything.
