no headlights on 1975 280Z
shadesh
Hello,
The headlights on my 1975 280Z does not work. I used a test light to test the three wires that plug onto the headlight and no power.
The park lamps turn on. The turn signals don't. The high beams don't work either.
I also noticed that at the steering column, there is a black (thin) wire that is not connected anywhere. My guess is that it should connect to the ignition??
I cannot remember the color of the other wire to the ignition, (White and red, or red)... but should the black wire also go to the ignition.
Is the open black wire at the steering column the reason the headlight is not working?
What can I do to get the headlights working? Please help.
Definitely check for that Black wire's corresponding connector. The Hi/Lo Beam switch requires a Black wire connect to the Combination Switch as well as a joint connection to the Windshield Washer. (As a check, you might check your W/Washer to see if it is operating.)
E
OK. I finally got to take a look at a few things. Here are my observations using a test light.
A)Tested the wires on the top of the combination switch and observed the following.
SWITCH OFF 1 2
WR ON ON ON
R OFF OFF ON
GW OFF ON ON
G ON ON ON
Is the above what I should expect.
B) I tested the wires at the bottom of the combination switch and observed the following. I don't know what those wires are for?
SWITCH OFF 1 2
RB OFF OFF OFF
BY OFF OFF OFF
B OFF OFF OFF
WB OFF OFF OFF
hmm.. does that make sense
I will test the fuse box next. The fuses should be on the two on the top left? can someone confirm. I don't have a fuse box cover.
Should they be on at all times or should they be on only when I turn the switch on to the 1 and 2 position?
Thanks a million.
They are the top two. here is a pic of the fuse box. I would replace them even if they look good. I had some that looked good but were bad. Plus some worked until i touched them!
Thanks for the diagram.. at least now I can test the right fuses. What are your thoughts on the observations I made on the combination switch. Do those look right?
Anyone.?
SWITCH OFF 1 2
WR ON ON ON
R OFF OFF ON
GW OFF ON ON
G ON ON ON
SWITCH OFF 1 2
RB OFF OFF OFF
BY OFF OFF OFF
B OFF OFF OFF
WB OFF OFF OFF
Thanks a million.
Can someone help me on my question above.? Please.... I really appreciate it.
The biggest problem with your test, is that you don't specify WHAT it is you're testing for. Add to that that you don't reference with respect to WHAT you are testing against.
ON = What? Voltage 12v or continuity? Continuity with regards to what? Voltage with regards to what?
Have you checked the wiring diagram for your year?
Did you check and/or replace those fuses? (Note a VISUAL check of the fuses is worthless, these glass tube fuses often look OK, but in fact are NOT.)
Have you checked to see if you have power at the headlamp connector?
Not trying to p*ss you off, but we can't see your car from where we're sitting, which makes it extremely hard to diagnose.
2¢
E
I am testing to determine why my headlight is not working.
I am checking for continuity. For example, when I turn the headlight switch once, the WR (white red) wire has power when I attach the test light to it... thus, "ON".
I have been studying the wiring diagram.. but sometimes checking in with folks helps... nevertheless, I will visit it again.
I replaced all the fuses with the correct ones. I cleaned all the connectors too.
There is power at the fuses for the headlights.. I tested all points of contact at the fuses for continuity.
There is no power at the headlamp connector for both headlights.
2¢
E
I hope this helps. .. and sorry for the inconvenience.
  • Who's Online   0 Members, 0 Anonymous, 627 Guests (See full list)
